Thanks for this. I did the same but was having problems with the passenger vented seat. Originally It worked when I selected to option for “vented seats present”. I guess I had since then changed the seat type to “perforated”. Everything still worked as should (heat/cool) except the passenger would cut off like you described except only on vented. Finally read this post and switched to “default”. Truck didn’t like this as the vented option still didn’t work and now the airbag system service light came on. Switched it back to “cloth” as this is what my truck came with originally and bingo, everything workin as it was the first time.
So I tried activating my inverter and to no luck.
Before I had the pin on the outlet connector (I believe pin 7) go straight to 12v and it would work like that.
Today I put it back to stock and I activated inverter present and dc to dc I verter and dc to dc inverter #2 and it’s not working.
Can anyone chime in?
Thanks
Try these settings:
Inverter Present: Yes
Power Inverter Type: Latching Switch
Inverter Status Input Present: Set
Inverter Enable Relay Output Present: Set
Also the DC to DC settings are 'not set' in my settings. I would change those back
Can I get someone with their AlphaOBD and truck nearby to verify a possible bug for me? Preferably on a truck with factory LED tails. In the Body Control Module functions, can you try the Left Reverse Light and Right Reverse Light functions? Only the Right one is working for me. The left bulb itself works when the truck is put in reverse, it's not out. It's just the test function in the app that not working. I'm using the current full Android version and the recommended Bluetooth MX dongle.
-K
Anyone know what the "Rear Fog Lamps" output to?
Look for license plate light and change it to led. That's what I did and I stop getting license plate bulb outCan we turn out the bulb out messages with AlphaOBD? Changed my tails, reverse, plate, and high mount bulbs to LED and I have the errors.
Sorry misread the postCan we turn out the bulb out messages with AlphaOBD? Changed my tails, reverse, plate, and high mount bulbs to LED and I have the errors.
Try these settings:
Can you disable mds with this?
