AlfaOBD
2019ram150057
US
when trying to program a fob how long does it take? i can get it to start but just seems to stay there i have a 2019 and have got the bypass cable for the security system. is there something that i am missing when doing this.
Jimmy07
Push button start fob, or regular fob? Where did you buy the fob? Is your 2019 a classic, or 5th gen?
06Silverhemi
would changing the year under car configuration give me more options to change ?
Sent from my SM-N975U using Tapatalk
Sdpadrez
I have noticed this to be true. When selecting 2013-2017 body computer you get less options rather than selecting a specific year like 2015, 2016 etc.... which gives more options.
SitKneelBend
St. Louis
3.6 Pentastar
Yes, I get a bunch of "2014 CBC..." Options when I choose my year and it connects to 2014-2017 Powernet instead of 2013-2017.
SitKneelBend
St. Louis
3.6 Pentastar
Should be ready in 30 minutes. I'll send a link...
Edit: wrong conversation, disregard.
06Silverhemi
Do you think if I change my vehicle Year from 2014 to 2015 under car configuration I would be able to access the other options?
Jimmy07
No. It will automatically only reveal the options for your BCM. You can manually force other years BCM options using advanced mode on the windows version.
06Silverhemi
Do you know if I have to buy the app again since I'm using Android? Or how would i do that
Richmond2000
what other features does the windows version have?
I know a while ago the 2 versions were the same with the android being more stable"
but if there are actual advantages to go to windows version say like "long coding" in forscan / VCDS
RLT1
FL
I’m new to the forum so sorry if this post if in the wrong thread. I’m wondering if anyone else has had the alfaobd body computer showing a different year than what their truck actually is? I have a 2017 but when Alfa connects it connects to MY2016. Any thoughts...
brianw0048
EcoDiesel
I think you can change the year in the configuration.
1500ram12
5.9L Cummins
It's possible that you have a very early run 2017 that they used a 2016 bcm in
2018 Ram 2500 6.4L Hemi Tradesman
Kenepo17ram
Brooksville, FL
I have a 19 1500 classic but alfaobd shows me 2018
Sent from my HD1925 using Tapatalk
chrisbh17
Mine is an early 2017 and shows up as a 2016. But I have a feeling a lot if not all 2017 show up as 2016. Like it shows the earliest year of the "generation" of BCM. 2016-2017 shows as 2016, 2018-2019 shows as 2018, etc.
RLT1
FL
Ok. Good. Glad to hear it’s not uncommon. I’ve changed several things with the alfaobd so I’ve left it alone. It’s working so why mess with it. Thanks for the reply.
RLT1
FL
I have a question about the interior lights. How do you change the courtesy light to LED on Alfa?
and I’m getting a side marker code. Any ideas on changing it in Alfa? I have LEDs all around and inside. Those are the only two codes I haven’t been able to get rid of
1500ram12
5.9L Cummins
Interior lights won't set a code. Make sure you have both turn and parking lights set to led, not just turn. Same for the rear if you changed those.
RLT1
FL
The code is for the courtesy light. I’m not sure why it would be going off then.
I’ll check on the other lights. Thanks again
