AlfaOBD
Lawsuit11
Fort Worth, TX
All right guys, serious question. Scotty1987 posted in DIY thread he changed his splash screen on the 7 in evic to a picture of his own liking. Did I miss something on this thread or is this April fools in July?
Sent from my LG-LS995 using Tapatalk
No it’s a pre set option in Alfa. He didn’t do anything special. Here is a screen shot of all the packages.
Note. Not all will work with our trucks
big daddys house
Hill Valley
Thank you Sir.
I let them know in the DIY thread.
Lawsuit11
Fort Worth, TX
Thank you Sir.
I think tomorrow when I have some free time(at work) I’m going to go through and try every single one and see which ones work. Lol it should take me a few hours to try them all depending on how fast they take to the truck.
big daddys house
Hill Valley
I would love to see BEATS and Super Bee as I have a 2014 evic and probably won't ever get so see them... [emoji17]
Cesar592
3.6 pentastar
ok guys I changed the miles in my cluster but as I manage to change the engine hours I still don't know how it works
Maligator
Hem 5.7
Wondering if you ALFA gurus can help. I recently dropped my pressure settings after I chalked my tires. My pressures in my tires were 43psi front and 35rear. I changed my threshold settings in ALFA tto 38psi front and 30 rear. We've been in the high 90s for a few weeks but had a cool evening last night. My rear pressures dropped down to 31psi. And for some reason my tpms light came on and stayed on even after my tires warmed up to 35. Any idea why my light would come on even though I didn't drop below the 30psi. Here's a pic after my tires warmed up on a 45 min drive6ffd0f293a61af48c335b56aeac1eb47.jpg
Ricks Ram
You are correct. Unfortunately the 2014 EVIC is only programmed to show the Ram emblem at start up no matter which option package you have selected in your BCM. Your BCM is capable of showing the different splash screens if you put in a newer speedometer. My truck is a 2014 and I was able to change them when I put in a 2016 speedometer.
WVRam68
WV
Did you add your pin and reset rfhub?
Just checking
Lawsuit11
Fort Worth, TX
I have received a few people asking how to program Lifetime drive and idle hours. I made a walk through to help people out. I will quote this post with the walkthrough.
@Big daddys house. You should do a video for programming the idle and engine hours if you can sir!
How to program Idle/Drive hours on premium 7” EVIC
Connect to your instrument panel and click the car with the hood open
Click on the drop down menu
Click on program custom features towards the bottom of the list
You will see a second drop down menu. Click on it and you will see your two options for programming your Lifetime idle and Lofetime engine hours
Your Lifetime Engine hours is the TOTAL hours your truck has been on. So you need to add your Drive and idle hours from your old EVIC together.
Example
Idle hours on old EVIC - 350
Drive hours on old EVIC - 605
Your Lifetime engine hours would be 955.
That is what you enter in the Total engine hours box Show in the pic below
Next click the second drop down menu and select Lifetime Idle hours
This is where you just enter your exact Idle hours on your old evic
After this your evic will calculate your Drive hours itself. So you don’t have to do anything else
Disconnect and close AlfaOBD like normal
Jeffreybunton
