Alignment issues....HELP!!!
BKNBK
MT. Vernon, IL
Hello again.
So I have my McGaughy's 3/5 drop installed. My alignment is way off (negative camber). I used the 2" drop spindles, 2" drop springs w/ a 1" Spacer from Belltech on the front.
My camber was way off on both sides. The alignment shop installed a camber kit and now the drivers side is close, but the passenger side is -1.5 degrees.
Is there any way to get this right? I have heard a few people recommend notching the UCA mounts. Is this acceptable and will it get me close enough?
Does anyone make longer UCA's?
PLEASE HELP!!!:boxed:
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Im not sure bud, theres alot of lowered knowlage here bumping it up for some of the lowered kings and queen.
B
BKNBK
MT. Vernon, IL
I think I'm gonna just try slotting the upper mounts. My alignment shop got it close, just need a little more adjustment.
B
BKNBK
MT. Vernon, IL
Okay, so it's been over a month now, but I did get the alignment right. I ended up slotting the UCA mounts about 3/8" each. That in combination with a camber kit did the job.
Now I have to install the C-Notch when it gets here!!!:********:
srt2slow
fort dix
viper v-10
what camber kit did you buy for the front....im only off by -1
B
BKNBK
MT. Vernon, IL
It was MOOG kit from Summit. I think it should correct up to 1 degree either way. Mine was off a lot more than that.
stevenmicheal
