alignment with bilstiens?
bryan28
Tullahoma, TN
2020 Laramie CC 4x4
If I install a set on front set at 2.1" will I need an alignment afterwards?
MR.Hemi
Yes, because it changes the geometry of the front end. Doesn't cost much to get it done
darendeath
V6
I haven't had my alignment yet. Was told it wasn't needed with the shocks, but would be with spacer to levels.
I'm getting new wheels and then I'll do alignment.
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
Someone lied to you then. You most definitely do need an alignment with Bilsteins as you've changed the whole geometry of the front end. Right now your tires will be towed in and you'll have positive camber. You don't need to wait for new wheels for an alignment... it can be done regardless of what wheels and tires are on the truck.
