Alignment?
Arell5080
Fairhope, AL
3.6 Pentastar
I have a 2017 1500 Lonestar 2wd.I can’t get the camber in spec on the drivers front side. It’s negative by 0.6 degrees. Two separate texts have come up with the same results. What gives?7017AC4B-E862-4EEF-A8C1-06AFA60D0DE5.jpeg
Dpressed1
Houston
I have a 2017 1500 Lonestar 2wd.I can’t get the camber in spec on the drivers front side. It’s negative by 0.6 degrees. Two separate texts have come up with the same results. What gives?View attachment 206406
Possibly bent suspension component. Most of the times alignment shops just toe-and-go. Just adjust the toe and dont bother setting camber and caster. Im a tech but dont do alignments, ive had my 17 ram with 33k miles aligned like 6 times and its still not set to my liking. But since i dont mess with alignments, and cannot find a good honest alignment tech to do it right, im just dealing with it.
bm02tj
B C Canada
Ask around for the guy that does the custom rods in town as he will know how to make it work
Or a 4X4 shop that builds lifted rigs
A
Arell5080
Fairhope, AL
3.6 Pentastar
Thanks. I’m going to check out an alignment shop next week.
