Alpha guru’s
22hemi13
Tucson AZ
2014 2500 4x4
Ok trying to update my tire size. It shows it took the change. However I’m getting serv 4wd, serv trailer brake and serv abs errors. When I try to do static ECU Initialization it’s failing. Deleted app and will try again. I’ve searched and get not a lot of info. Any help?
2014 2500
Gear Jammer
Yacolt WA
Cummins
Don't know if you've gotten this fixed yet, but when I did it I didn't do a "static ecu initialization", I did an "ABS Initialization" they appear to be right next to each other in the app.
heckcat9
UT
Which body computer and control unit are you connected to?
This doc was a lot of help when I was setting my tire size. The static ECU init shouldn't have any issues after your tire size is set.
22hemi13
Tucson AZ
2014 2500 4x4
I got it all fixed. I was not doing my math on the tire size right. Oops. Apparently the truck even with alpha won’t let you run 80” tires lololololol
