Alpha OBD help?
mks1775
Celina, TN
6.7 L6 Cummins
So I did not have logging enabled before I made some changes. Long story short, my intermittent wiper s setting do not work. The active when turn on, in low and high....but not in the intermittent settings. Any advise or help?
mtnrider
Georgia
Under "CBC Features Configuration:" check "Intermittent Wiper States: 5 Intermittent Wiper position Switch"
That is one I found in my log for my 2016 that could be the issue?
mks1775
mks1775
Celina, TN
6.7 L6 Cummins
Which module is it connected under?
mtnrider
Georgia
Body Control Module / Car configuration Change / CBC Features: Intermittent Wiper States
Then it gives you options to chose, mine was set on the 5 switch. May not be the answer but it's the only thing I can see that has todo with intermittent wipers.
It makes it easier to find if you just type "wiper" in the search bar once you are in the car config change menu select option section.
mks1775
mks1775
Celina, TN
6.7 L6 Cummins
I changed the setting, but still not working. Here are the fault codes, but I have no check engine light.
mtnrider
Georgia
Do you have the auto on rain sensing wipers?
mtnrider
Georgia
If it's throwing a fault for them they might have been enabled in Alfa some how? That could be throwing everything off. Getting into tricky territory without a original log though?
There is a setting for Auto Wipers, might be worth a look to see if it is enabled?
mks1775
mks1775
Celina, TN
6.7 L6 Cummins
I changed a few things and After a few drive cycles, they started functioning normally. Thank you for your help!
mks1775
mks1775
Celina, TN
6.7 L6 Cummins
Any advice to get my interior lights to function normally? They do not come on when the doors are opened. I'm sure I messed it up.
