BlownGP
- Feb 10, 2013
- 6,079
- 1,571
- Location
- Houston/Baton Rouge
- 2018 RAM Harvest New Holland Blue
- 5.7
I had the alpharex g2 pros on my 19 classic. Had similar issues with the bulb out warning. It's correctable with resistors if alfaobd can't eliminate the errors. That said, I am currently running a set of alpharex made oem style projectors with hid low beams, led highs and have zero issues. I've changed all my bulb settings to led/hid and set my turn signals to function as the drl. The beam pattern is pretty good, highs are very functional (something I really didn't like about the g2 pros was the poor high beam pattern). The lights fit and function great and are well worth the money, especially if you like the look of the oem projector setups. Either way, you'll want to get the kaodtech security bypass harness, alfaobd and a blue obd2 adapter so that you can change the settings. I'd also recommend hid for low beam projectors to get the best pattern and output. FYI, none of my bulbs are canbus compatible nor am I using resistors or capacitors or other modules to make things work.
Those look good. Which LED bulbs did you go with?
