Alpharex NOVA headlights installed and review.
1500ram12
5.9L Cummins
I just got done installing my alpha Rex Nova leds. They are fantastic, I don't have any error codes and they work great! My only problem is adjusting the height on the left fixture. There is certainly no screw in any of the adjustment holes. I might have to pull the fixture see if there are any other adjustment screws somewhere else. 2018 ram 1500 limited
If you look down through the factory hole you'll see what looks like a gear. That's your adjustment screw. Use a Phillips head bit to adjust
2018 2500 6.4L Hemi Tradesman
1990 5.9L 12v Cummins W250
Yellosuzku
Massachusetts
Installed the alpharex novas in my 17 2500 that had stock quads, I get the park lamp out error on initial start up. Not too bothered by that, however I have had the lights cut out twice on me while driving at night. Any ideas what this issue could be? Turned headlight switch on and off and lights came back. Love the new light output but not so thrilled on the headlights cutting out....
1500ram12
5.9L Cummins
You'll want to use alfaobd to make some changes.
You'll want to enable high intensity discharge lights. This disables pwm. Which causes the issues with led/hid's
Then you'll want to set the park and turns to led's. This may or may not work. It seems to be hit or miss with the alpharex lights
Yellosuzku
Massachusetts
Thanks for the reply! I’m sure this question has been asked a million times but what would be my best course of action to set myself up with alphaobd? I do not have an android. Thanks in advance!
1500ram12
5.9L Cummins
If you have a windows laptop you can go that route. If not, I bought a Amazon Kindle fire 7 tablet for $50 and downloaded Google play store (lots of YouTube videos with apk link's to do it) then downloaded alfaobd.
Corey3146
Pittsburgh
Just installed these headlights on my 17 Laramie longhorn and you could see the adjustment gear threw the holes like you say but the philips head screw faces the tire instead of being straight up and down like the OEM headlights. It is not possible to get at that adjustment screw on the alpharex without completely removing the headlights.
I ended up drilling holes in the plastic “frame” that the headlights bolt into so I could gain access to the adjustment screw threw the access door in the wheel liners. Makes adjusting the alpharex lights so much easier.
So far I love these lights but I can’t believe they would put the adjustment screw in such an inaccessible spot.
Administrator
Your doing it way harder than it needs to be. If you notice the edge of the adjustment screw looks like it has teeth on it, those are what the Philips screwdriver meshes with to turn the screw. I have a 12" #2 Philips screwdriver that works perfectly through the hole in the fender to adjust the headlights.
Corey3146
Pittsburgh
would be nice if alpharex actually put instructions in there product. Oh well, I’m still happy with them.
rule18
Admin
Administrator
NY
2017 Rebel
^ Yes, this.
Nerveex
Syracuse NY
It's the cut-off of the projector. That's the way they are designed. Some are more pronounced then other's
So I just need some clarification how high off the ground is the cutoff supposed to be? I need to adjust mine currently as they are too low it seems and I don’t want to go way high and blind people.
F Baum
Davie FL.
6.7l
I have a 2015 ram 3500 with quad headlights and I just recently purchased some alphaRex luxx headlights and no matter what I tried on alfaodb I kept getting the front parking light out message every time I used the blinkers with headlights on.
i did what"AE5548" did I put the LED front turn Lamps to no/off and kept the LED front Marker lights to yes/On I made four separate trips tonight and it never came up it's just stored in the messages but it never pops up no matter how many times I used the blinkers!!!!! I also turned the headlights on (not auto) in the daytime today about five or six times and turned the turn signals on and I didn't get any messages neither.
Honestly I wouldn't care if it came on once when I first start the truck but all four trips I made tonight it didn't even do that it just stayed saved in the message center
These the two settings they said to change. I have since switched my turn signals back to LED no and I get no lamp out messages.
Wulf
United States
@AE5548 I am curious, this far in since your OP. Do you still have these lights on your vehicle? And if so, what are your thoughts this far out? Since you have had a chance to well use/get used to them, etc.
am3334
