Alpine system - Headliner speaker replacement
ksn240
Anybody replace the speakers in the headliner yet? I'm getting ready to swap out the dash speakers and figured I would do the headliner speakers also. According to Crutchfield, the headliner has to come out to get to them. I went outside and tried to pry the covers off and could not get them to pop out. I was afraid to apply too much pressure. Anybody?
Planning on using JBL GX302s as they are 2.3 ohm speakers, about as close to the stock 2 ohm as you can get.
Geoman15
Louisville, KY
I replaced mine. The covers will come off but are super hard to get off.
I used the plastic trim removal tool from harbor freight and pulled them off.
Got one out and used brute strength to pop the others out. Seemed the left one's came out easier and the pulled the rights out.
One of the clips came off the cover and had to put it back on the cover, but no biggie.
Rear fill was much better with the new speakers.
Good luck with yours.
George
K
ksn240
George
Glad to hear they do indeed come off after Crutchfield saying they won't. I'll get the trim tool this weekend. I was just using my fingers more than anything. Didn't want to take a flathead to it and tear it up. I guess I will call Crutchfield back today and order the set for the rear.
K
ksn240
@Geoman15 Time to replace the headliner speakers. Got the grills off, they are on tight! Did you have trouble mounting your replacements? It seems like anything other than the factory will not fit very well. The plastic housing that holds them will not let me rotate the speaker to get to the screwholes. Did you have to fab something up or did you just make new holes?
Geoman15
Louisville, KY
My new speakers fit and screw holes lined up easily.
My tweeters protruded a little too much so the covers aren’t 100 percent flush, but’s close enough for government work.
runamuck
dfw
6.7 dsl
I am a JBL guy going all the way back to my 1976 L100 studio monitors in the house and all JBL 7.1 surround system for our main tv area but am curious if you guys found any other rear headliner speakers besides the JBL GX-302 that will work. they are pretty cheap. are they the best replacement option. also, what has been found for the front doors?
K
ksn240
Other speakers will work. The JBLs are not a direct drop in for the headliner, but I can rig up something to make them work. For a direct drop in, you need something where the speaker mounts are to the side, with the terminal connections dead in the center between them, instead of closer to one side or the other. I believe @Geoman15 used a different speaker than I did or he would have ran into the same issues.
For the front doors, they are bass only in the Alpine system so 2-ways and 3-ways are overkill as the tweeter will not get anything. That being said, I will still be dropping the GX963s in the front when I get the chance, just because that is what I put in the rear and I got a good price on them. They are also 2.3 ohm while the stock Alpines are 2 ohm, so nearly a perfect match. CDT has some 2 ohm 6x9s that would probably be much better, but I am not looking to splurge at the moment, just wanting to clean things up a little. The JBLs will accomplish that just fine.
Geoman15
Louisville, KY
These are the speakers I use. They mounted up perfectly. Only issue was the covers for back a little proud.
https://www.sonicelectronix.com/item_69258_NVX-NSP35.html
George
chrisboy68
ORLANDO
Doing this too. Did you find a speaker harness that fits? If so, do you have a link?
Thanks
Chris
K
ksn240
Buy them from Crutchfield and the proper harness is included. Fitment was the bigger issue. I had to turn them a bit and drill new screwholes and all is good.
Eric-H
Tampa, FL
3.0L diesel
I know this is an old thread, but has anyone tried enlarginging hole and putting larger speakers up there?
reb0957
Broussard, LA
5.7l
I thought the premium system was Hk, Is the Alpine system the 9speaker system with subwoofer?
Thanks
runamuck
dfw
6.7 dsl
I have the Alpine 9 spkr setup and am wondering which Alpine spkrs they use so as to compare possible upgrades. The NVX spkrs mentioned above are really low price..are they really very good..just looking at as many options as I can before starting this project.
toejam
6.7 CTD
I used Hertz Energy ET 26.5 tweets in the headliner and custom a-pillar pods, but I have a total custom setup.
