Alternator question
Discussion in 'Engine & Performance' started by Moparornocar0346, Nov 2, 2018.
Sponsored By: Moe's Performance
  1. Moparornocar0346
    Moparornocar0346 Senior Member
    29
    134
    38
    Aug 11, 2018
    Mount Sterling
    Ram Year:
    01
    Engine:
    5.9 liter
    Ok my alternator just started to make a bearing noise. So was told there r two different ones for my 99. Either the 117 or 136. My tag on mine was gone so don’t have a part number. So honestly does it really matter tho
  2. rrb6699
    rrb6699 Senior Member
    39
    123
    May 31, 2018
    Orlando FL
    Ram Year:
    1996
    Engine:
    5.2 / 318
    no vin#? with that you can find the build sheet and see what alternator was installed.
  3. Moparornocar0346
    29
    134
    38
    Aug 11, 2018
    Mount Sterling
    Ram Year:
    01
    Engine:
    5.9 liter
    Well I got the vin yea but would I have to call the dealer to see about the build sheet?
  4. Snowmanak406
    Snowmanak406 Member
    77
    Oct 22, 2013
    MT
    Ram Year:
    1997
    Engine:
    Magnum 5.9
    as long as they have the same plugs should be able to use either or, if you have many electronics (sound system/light bar) id go for the higher amp one either way, but if it had the oe lower amp one and you want to keep exact original get the lower one.
  5. Moparornocar0346
    29
    134
    38
    Aug 11, 2018
    Mount Sterling
    Ram Year:
    01
    Engine:
    5.9 liter
    Well I do have any system or light bar at the moment but maybe in the future. I thought about going with the higher one anyways just in case I get something later
  6. Snowmanak406
    Snowmanak406 Member
    77
    Oct 22, 2013
    MT
    Ram Year:
    1997
    Engine:
    Magnum 5.9
    I would personally go for the higher one, these engines aren't starved for power so a little more draw from the engine won't be a bad thing, and if those items are possibilities in the future and they do draw to much from the small one you would be getting a higher rated alternator anyway at that point.
  7. rrb6699
    39
    123
    May 31, 2018
    Orlando FL
    Ram Year:
    1996
    Engine:
    5.2 / 318
    I got my build sheet on the dodge site. someone here gave me a link.
  8. Moparornocar0346
    29
    134
    38
    Aug 11, 2018
    Mount Sterling
    Ram Year:
    01
    Engine:
    5.9 liter
    I actually ended up matching one up and it ended up being the 136 amps
    rrb6699 likes this.
Share This Page
