Am I missing something here?!
omaha123
Nebraska
5.9l CTD
So trying to change my gear oil. Here's the problem. Why the heck would dodge use a hex head full plug ? retarded....5agureta.jpg huta6yra.jpg off to try and find a 9/16 Allen key.
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
Uhm. The fill plug should be a plastic/rubber piece on the actual cover shouldn't it? I'm not entirely sure what that is.
Trupiano
Registered User
6.7L CTD
That might be a port for a temp sensor. I don't believe the OEM covers have drain ports. You have to purchase an aftermarket such as the mag-hytech to get the port. Gotta take the cover completely off to drain it.
BlackedOutHemi
DFW, Texas
2012 & 2012
If you're looking for a drain port, they don't have em. If you're looking for the fill port. It's the rubber plug on the front.
To drain it, you just have to start pulling the bolts until fluid flows out.
LB3711
Trumbull, CT
3.6L V6
11's and up had a TSB for some drain back thing and they also changed to the plastic plug cover from the older rear ends.
I had this before the TSB
what i have now
omaha123
omaha123
Nebraska
5.9l CTD
Okay, I'm following. I was planning on removing the cover to drain. So to fill it I should look for a rubber plug?
BlackedOutHemi
DFW, Texas
2012 & 2012
Yep! There's one on the front like Matt showed. If you don't have it...I don't know how you'd change it. So might need to pick one up from the dealer if not.
omaha123
omaha123
Nebraska
5.9l CTD
eruqemyr.jpge6y3agah.jpg I can't find a rubber plug. That hex head is the only thing that is a hole. Wtf?!
Black Cloud
Oxford, PA
I don't know...looks like the fill plug on my '05 Magnum to me...what else would they use? I've never seen anything different and I've been doing this a long time.
BlackedOutHemi
DFW, Texas
2012 & 2012
Refer to Matt's post. He had to have his gear cover replaced because they didn't put a rubber plug in the front.
omaha123
omaha123
Nebraska
5.9l CTD
I gotta buddy's who's a service tech at the Chrysler dealer. We will see what he says about this weird hex thing haha
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
I swapped the diff cover in the back so I could have a threaded plug with hex head like you showed because I did not like only having a rubber stopper only in there. How in the world did they even fill those axles without the fill hole that is crazy.
$miley
omaha123
omaha123
Nebraska
5.9l CTD
that hex head is the fill hole apparently on my differential... took about 2.7 quarts and limited slip additive. The front one was a rubber stopper, which i'm not the biggest fan of...
No members online now.
TheM4rxxx
