Amp Power Wire Question
Bluesmoke91
2nd GEN Site Mod
Baldwin Park, California
do our Rams come with a hole in the firewall that we could run a power wire through to the fuse/battery...or am i going to have to drill a hole and buy a grommet?
jhemi
wisconsin
i drilled my hole where the clutch set up would be attached they put a plastic cover there i drilled the hole perfect size didnt have to use a grommet
adamwilkes14
There should be access grommets in the firewall for the harness etc to pass through...
bigtigga84
dela....where?
How big is the wire your Tryin to run? I used the grommet for the parking break cable
adamwilkes14
Where are you mounting the AMP? If you are mounting it to the rear of the front seats, it would be easier to use a grommet on the back of the cab...Unless Chrysler didnt put grommets back there like GM does
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Theres a grommet there that you can cut alill bigger to allow more cables to run through. I have both my amp wire running through it along with my wideband wires.
Bluesmoke91
Bluesmoke91
2nd GEN Site Mod
i was planning on mounting it under the driver side seat..do you or anybody else suggest somewhere else?
a grommet where?
OklaHemi
new age hemi
do this
Bluesmoke91
Bluesmoke91
2nd GEN Site Mod
there is a hole in the firewall right behind the gas pedal with the cable from the hood popper going through it...not sure if it goes completely through to the other side but would i be able to run the cable through there?
weedahoe
Banned
South GA
cammed and custom tuned 5.7
Ive got my 2/0 going through my clutch plate cover also
stevenmicheal
