Seanbeck1
Thank you very much! What size do you have?I have them for daily use. So far so good. More of an all terrain with an aggressive look. Not that loud either
305/70-18. I will caution, I was given a huge headache getting one to balance. Over paid with all the balancing I had to get done. I ended up having to order a 5th tire and send the bad one back. The shop said it was unbalanceable because it was out of roundThank you very much! What size do you have?
i don't think they are only for mudding from reading description but more of an off road option for sure.
What PSI are you running these at? I had 41 in the rear and it seemed like the tread wasn't fully hitting. I have 35x1250 r 20
I have a 2500 so I’m at 65psiWhat PSI are you running these at? I had 41 in the rear and it seemed like the tread wasn't fully hitting. I have 35x1250 r 20
Yep, they will wear heavy in the center. If I aired down under 40 they were noisy and unstable in cornering.
My tire show marks are actually wider now with a 275 than those 13" wide Amps.
How many miles did you get out of them?
