Amplifier ground?
Nesto1000
Houston, Texas
4.7L Magnum
So, I recently followed the Rear Seat Flip Down DIY by RubberFrog and it is amazing! Now I want to put my mono amp in the back just like RubberFrog has it, but I don't know where to make the ground at?
HKkid
Missouri
Find a bolt. If it goes into the body you will be fine, or find some bare metal, look underneath the truck and make sure there's nothing important underneath and drill a hole, insert bolt through connector, attach bolt to other end. Just make sure that there is no paint so you get a good ground.
Nesto1000
Nesto1000
Houston, Texas
4.7L Magnum
I've been doing some research on google and they said that the blot for the seats is fine... but I'm not too sure about that... :/
Paint isn't an issue either, I have a grinder and sand paper if needed...
HKkid
Missouri
Bolting to a seat bolt would be fine. It goes into the body and will be a fine ground. Thats where mine is grounded, its just the front seat.
Nesto1000
Nesto1000
Houston, Texas
4.7L Magnum
Ah sweet!!! Guess that I shall be doing that as soon as I get my 0/1 Ga welders wire! :D
Can you post up a pic of how you have yours done?
I shall post pictures of it when I get it done... but it might be in a while tho cuz I'm buying my mom a new TV for her birthday and I'm not gonna be a cheap ass... :p
HKkid
Missouri
I don't have any pics of it man, but I mean I literally took the bolt out, had a O connector on the end of the wire, fed the bolt through it and tightened it down.
LB3711
Trumbull, CT
3.6L V6
i used the seat bolt. I just cleaned all the paint around the bolt hole and where the ground wire lug would be sitting to make the best connection. works perfect for me.
Nesto1000
Nesto1000
Houston, Texas
4.7L Magnum
Hmmm... guess that I'll sand down where the bolt goes along with the washer... so I'll just the back bolt for my mono amp, and the front one for my 4 channel then... :D
Also quick question... should I use the 1/0 Ga Welders wire for my amps as well? If I have any left over that is? :D
LB3711
Trumbull, CT
3.6L V6
bigger the better but I'd use wire more designed for audio equipment. there is a difference. Someone else can chime in and explain it better
Nesto1000
Nesto1000
Houston, Texas
4.7L Magnum
The main difference is that one is flexible and the other is not so flexible... Well at least from what I've read that's what the difference is.
Sent from my MB525 using Tapatalk
jhemi
wisconsin
welders wire can sometimes be cheaper, but main reason people use for audio is welders cable usualy has more copper than audio wire unless you go with high grade audio which can cost up to 6 bucks a foot, more copper in the wire the better the current flows, doesnt matter much unless you do competition or pulling some serious power
Nesto1000
Nesto1000
Houston, Texas
4.7L Magnum
Really? Well I did find out that it was pretty cheap at about $3 potter foot at a local welding shop... And I assume that welders $3 0 GA is a lot better than $3 0 GA audio wire?
jhemi
wisconsin
it is better, but like i said doesnt make to much of difference unless running serious power, im running 4 class d 3000 watt amps and using audio wire, i paid i think 54 bucks shipped apiece, for 2 50 ft spools, but really its up to how much a person wants to spend in the end
LB3711
Trumbull, CT
3.6L V6
what size amp are you using wattage wise? Do you really need something that big?
Nesto1000
Nesto1000
Houston, Texas
4.7L Magnum
Well, I'm going to get the 1/0 GA Welders wire since I know that it's at least quality wire...
As for what I'm running, right now is around 850 Watts RMS running at 2 Ohms. I'm looking to get some new subs later and run em at 1500 Watts RMS at 1 Ohm. Oh and I'm also running some pioneer 4-channel amp that I'm looking to replace with something else...
jhemi
wisconsin
well sounds like your on the right track then
Nesto1000
Nesto1000
Houston, Texas
4.7L Magnum
So this weekend I went to check out the 1/0 GA wire at home depot... and well it's effin hard!!! The 1/0 GA wire at another welders shop had wire that was a lot more flexible!
stevenmicheal
