Annoying Squeak
HemiBabe
DFW
Thought it was my CAI tube squeaking but I just bolted it in again and its not it. It sounds like its coming from the front passenger side and it squeaks on every bump and is embarrassing. I don't think its any of the suspension and I cannot find what it is but its metal on metal squeak.... any ideas?
[ tapatalkin ]
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
Is it a squeak you can get by bouncing the truck yourself?
HemiBabe
HemiBabe
DFW
Well Terry just made it bounce up and down and couldn't get it to do it again
[ tapatalkin ]
BlackedOutHemi
DFW, Texas
2012 & 2012
I would think if it was suspension you could get the sound from bouncing it. But I don't know much about that. Does it only happen over larger bumps/something that'll put more downward force on the engine bay area?
HemiBabe
HemiBabe
DFW
Its like on these bumpy roads in midlothian, there are bumps everywhere on these side roads, its like when the right side goes over small bumps and stuff, its hard to explain i guess. I guess it'll just have to squeak lol i have no clue what it is
bigbadram1500
Springfield, IL
When I had my squeak, I couldn't get it to replicate when moving the truck, but it did end up being the suspension and I had the struts replaced.
HemiBabe
HemiBabe
DFW
did it sound like metal on metal?
bigbadram1500
Springfield, IL
I thought it did. It was high pitched and really loud and would squeak at the slightest bump.
HemiBabe
HemiBabe
DFW
i didnt think our trucks had struts?
HemiBabe
HemiBabe
DFW
Ya mine has just shocks lol
[ tapatalkin ]
shikityshack
internal combustion
Just to clarify 06 - current 4x4s have struts.
W/o hearing it myself, and you saying front end, my first thought is sway bar bushings. Easy to find out, its only 2 nuts and you can disconnect the sway bar, go for a short drive, see if it sqeaks.
AJMAG
new jersey
I was gonna say sway bar bushings too. My cummins needs new ones and sounds like metal on metal as well
HemiBabe
HemiBabe
DFW
ahhhhh! good idea! I will check this tomorrow if it ain't raining, THANK YOU!
nussdawg395
PA
5.9 Magnum
If all else fails, grab some wd40 and hit every pivot point you see!
HemiBabe
HemiBabe
DFW
Man it is gettin worse, I just went out and looked, the sway bar bushings on the outer ends are starting to look dried out, I sprayed WD-40 on em, and gonna go try it out in a lil bit when I can get away from work... But I'm thinkin I might have to replace those bushings to fix it totally
rocket
Licensed Dynacologist
Pennsylvania
was 2006
was a HEMI 5.7
wow she works a long time..........................................................................................................................zzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz....................................................nothing yet? I would not hit everything with the wd 40. btw. just a section at a time. Ie; upper control arm bushings, check squeak, then the lower arms, check squeak. and so on till you hit the spot. otherwise you'll stop the squeak but wont know where it was from. wd-40 works, but not a long term fix by no means!
