Another AlphaRex Headlight Question
Sinistre1
@Morales how do you have your drl's ser up? Did you do alphaobd setup or the dedicated fuse tap? If one does the aplhaobd set up, is the dedicated line even needed or does alpha rework the drls just using the main harness? I have a '16 sport (not sure if that makes a difference)
1500ram12
5.9L Cummins
When you buy the headlights you'll select that you have oem projectors for the adapter harness. It appears they've added the dedicated drl feed into the harness so everything is plug and play. No tapping for the dedicated drl's. You simply plug the red wires coming out of the headlights into the projector adapter harness and you are all set. You shouldn't need alfaobd
2018 2500 6.4L Hemi Tradesman
1990 5.9L 12v Cummins W250
cmorales30
cmorales30
5.7 V8 Hemi
So I used the DRL relay harness that AlphaRex provided. I just used a fuse tap into F66 I believe. Then the back of the headlights have male ends that you just plug into the harness, which was pretty straight forward. d26beafec13b73f50a5f3b7fca1b6300.jpg
The DRL’s on the headlights light up white and then switchback to orange for the turns/ hazards. I didn’t go the AlfaOBD route since I don’t have the program yet.
Sinistre1
I purchased mine more than a year ago. I'll have to check if my harness is set up that way. Ultimately what I want is to be able to add the DRL on/off to my radio screen. I'd rather not have any fuse taps at all so if alpha allows for that possibility (everything done at the headlight/ harness AND I can switch it on and off at the radio I'd be Golden!!
1500ram12
5.9L Cummins
Yes alfaobd can give you that option. I'm not sure how long ago alpharex added in the dedicated drl wire to the projector adapter harness
Justin33
Wait so if you have Alfa go don’t need the tap? Does it matter if I have wild headlights as last I knew these are easier to setup and do t need adapter like you would for sport projectors.
hunterdan
SE PA
2019 classic
If you had oem projectors, no. If you had anything else, you'll need the tap unless you want to add the extra oem drl harness and activate it via alfaobd. The fuse tap is stupid easy and only takes about 5 minutes to connect.
Justin33
I was reading on one of the models that they changed the wiring and I could do it with Alfa. Debating if I just go xbs maybe the actual led chip I better than me putting something in plus five year warranty.
hunterdan
SE PA
2019 classic
The anything with a dedicated led projector setup is better than putting led in a halogen projector. The morimoto may still need you to do the fuse tap for the drl. Like I said, if you didn't have oem projectors, then you don't physically have the drl wiring in your truck unless you add it yourself. If you add it, you'll then need alfaobd to enable it.
Justin33
I’m lost so quads don’t have drls but projectors do? So now I’d need to get the mod2 wiring and pin it ect?
1Popeye
