Another Bils question
JRam813
I have looked and found answers on both sides of this discussion. I found that totally aweosme sticky about lifting. My head has been doing loopty loops trying to keep up! So here are a few things I wanted to go over regarding lifting/leveling with Bils.
If I use the 5100's on the front, set at 2.8 then I DO NOT need to do UCA's? When I looked at the cheaper hockey puck style (before I found this awesome forum) I found a lot of data showing it was recommended to do the UCA with the pucks. Since the angle changes with the Bils, doing the UCA is not needed, correct?
Do I need to do rears to keep the look of the truck level (rake)? A close friend that I trust did all four with Bils and did the Tuff Trucks rear springs also. It added capacity to his and a little bit of lift. I couldn't tell a difference by sight when looking at it. But, if I do add the springs, are Bils necessary? Do I need to anything to the rear whats so ever?
I think those are my final questions so I can purchase everything I need.
Thanks in advance!
2011 Ram 1500
You don't "need" to do new UCAs but it is smart to go ahead a do it since it is only a few more steps when installing the bils. Saves you pain in the future.
If you set the front at 2.8 the frontend will be slightly taller, but I don't think anyone will notice it unless they sit and stare at it.
madrock
The 5100 lift using pre-load and don't extend the shocks like a leveling kit does. Stock UCA's are fine but you should always keep an eye out for the ball joints regardless.
Every truck is different. Mine is a midget compared to other 4WD Ram's. Some can go without altering the rear while others get a 3/4" lift. The best route is to install the front, get an alignment and let it run a few days to settle. From there, decide if you want to touch the rear.
JRam813
JRam813
What is a good place to purchase all these suspension parts from? (site sponsor?)
Do we have a thread with P/N for everything too?
BLS
Minnesota
2016 1500 Sport - Blue Streak
Looks like we're being "that guy". I'm with you man. But I'm lost. You sound like you've got an idea of what you're doing.
JRam813
JRam813
I do ( I think).
A close friend did front Bils set at 2.8, rear Tuff Truck ( I think that's the name??) springs and rear Bils as well. It looks very nice and he said it rides great. I think that is the way I am going.
R.L.K.
Bristol , Tn.
I agree with madrock above , do the bills @2.8 in the front , get an alignment and drive it a few days befor taking any measurements . After driving for a few days the front will be settled in and a good time for measurement.
At that point just know over time 6+ months or so the bills up front will drop about a 1/2" so if you choose to add spacers to the rear coils keep the 1/2 drop in mind .
Just so you know , the rear bils are not the 5100s and do not provide lift to the rear , they are great shocks though .
I recommend doing the bils yourself , seems more issues are created when folks have a shop do it .
Either way , if you haven't seen my bils install post I'll post it here .
https://r.tapatalk.com/shareLink?ur...&share_tid=79370&share_fid=17770&share_type=t
Alright guys.. BILSTEINS post your pics!!!
Hope this helps !
JRam813
JRam813
Hope this helps !
It does! Thank you! I'm searching around for where to buy everything currently.
R.L.K.
Bristol , Tn.
Check out this link below , ( Brandonjanson ) is a fantastic source for Ram lift questions and information Sir .
I'm not familiar with the email address he provides here ,but I've never seen him send anyone in the wrong direction .
This link takes you straight to the post to the email provided by Brandonjanson , for a great guide to Leveling with all the info you need for level kits and tire sizing and more just go to post #1 and start reading .
https://r.tapatalk.com/shareLink?ur...&share_tid=70918&share_fid=17770&share_type=t
Guide to Leveling & Wheel and Tire Sizing for 06+ 4wd Ram 1500's
Hope this helps !
JRam813
JRam813
Hope this helps !
Thank you very much, sir!
shaunnz
