i updated mine last night also. when i hooked up the updater screen locked up three times finally on the 4th time it completely downloaded all the updates. then it had to prepare all the updates and write them to the tuner and that took another hour or so. havnt hooked it back up to my truck yet to see if anything changed. one thing i did notice though is that when i hooked it up to my computer it said it couldnt find the driver for it. also how do i view a datalog on my computer instead of my tuner?
on a side note from tuner to computer issues, i am having a wierd a shifting problem. in the morning when i start my truck and go to reverse no problems and reverse to drive no problems. in the afternoons when i get off work, mind you its 105ish here in AZ, i start the truck and go to reverse and there is a 3 to 5 second delay, by that i mean i cant feel it go into reverse within the normal one second it usually takes and the same going to reverse to drive. checked trans fluid and it is nice red color and full. i have tried a couple failed attempts at a power brake burnout maybe 2 seconds, let off as soon as i notice the tires arnt breaking loose. how in the hell do i do a damn burnout in this truck? anyways, what could the wierd shifting be caused from? was thinking about going back to a stock tune?
