another engine noise thread!
CunningStunt
Abbeville, AL
5.7L Hemi 4X4 Crew White/Chrome
2014 1500 4x4 139k - bought at 46k and have rotated oils between redline 5-20, 5-30, and PUP 5-30 and recently 0-40 right after noticing noise a few weeks ago.
To date- the engine had been a relatively quite and trouble free engine - only a smooth sewing machine sound.
So, after a cold start one afternoon, it was 45f outside, I heard an engine noise.
It was not consistently on every revolution, but was an intermittent and semi synchronous metallic ping type noise that tracks with RPM's. its like a ping-ping-pause-ping-ping-ping-ping-pause and the ping is not like a high pitched ping, it does however sound like metallic bubt kind of muffled
I am hoping its an exhause bolt however, ive had an exhause "leak" on another vehicle that was more of an annoying loud whisp.
Sound quiets a little bit at higher rpm's and when worm but not a whole lot.
I have not had any header bolts replaced to date.
Thoughts...? I will try to get some audio up soon
EDIT: Amplifying information - its pretty loud, this is not a subtle noise
Burla
2010 Hemi Reg Cab 4x4
You tried all of those oils in 2 weeks? Mine took 500 miles, others have taken 1700 miles, one 2300 miles, it is the science of the formula. Redline takes up to 1500 miles to work in many cases. Have you checked exhaust bolts?
CunningStunt
CunningStunt
Abbeville, AL
Lol no no no! Sorry i didnt clearly word that haha
Ive just used all of those oiles on my oil changes. I only have one oil change that I took it somewhere and had it done, all other oil changes I did and used RP or SRT filter.
I used the PUP 0-40 this most recent change when I first had the noise show up. and am about 700 miles into the new oil
Burla
Thanks for clearing it up, so it was quiet on redline, latest oil change PUP 0w40 showed up right away or after some miles? level on dip stick is good?
CunningStunt
CunningStunt
Abbeville, AL
I have never had a noisy engine on any of the oils ive used, the previous oil before my recent 0-40 was PUP 5-30.
So to be clear, I have never had a noisy engine - this sound came out of nowhere and has been persistent. Might be good to note I am in alabama and this alll occured on a cold evening and since has not gone away, but the noise is persistent but not quite synchronous as I would expect a lifter thats bad to sound.
Oil level is SAT, and I admittedly changed my oil at a higher 8000 mile OCI- but am not blowing smoke when I say that 95% of the miles on this truck are rural highway miles 50-70mph and one stoplight before pulling into my warehouse.
Burla
I'd look hard at exhaust bolts, the one thing with 0w40 PUP is shear, so it is susceptible to noise but usually only after 500 miles plus, if it was noisy right after the change, I would first think it was bolts. If you can see any bolts loose, maybe you need to do another oil change just to verify. Take your webcam out and capture at least 30 seconds, upload to youtube. If I had to guess, I'm thinking your issue is bolts.
CunningStunt
CunningStunt
Abbeville, AL
Thanks, i am really hoping it is bolts or I even saw someone state that rocks caught in the heat shield can also make a similar noise.
Burla
So now I'm on the other side, I think that is lifter tick, especially if it sounds like that warm idle.
Burla
So this happened right after PUP 0w40? like immediately?
CunningStunt
CunningStunt
Abbeville, AL
No sir, this happened at random one day, then changed oil to see if it helped quiet it, but it has not stopped since. It actually was quiet when I started up the truck, rode a mile to gas station, and recorded the video when I got back just now.
Burla
how many miles on pup 0w40 did this show up, aprx if you have too. What oil did this start on? what oil did you change it? need better histology here. how many miles on current oil change?
CunningStunt
CunningStunt
Abbeville, AL
I had ~6000 on 5-30 PUP -> Sound started ->immediately changed to 0-40 PUP and SRT filter ->700ish miles in - sound still showing up
Burla
I'd dump some lubegard biotech 15 ounces in and see if this changes sound at all. This is what we call poor mans redline, it is a moly boost with esters and phos, built to alleviate ticks. Give that moly in pup 0w40 and kick up and allow it to plate if possible. I would try this first, but you know what I would say next? If that doesn't go = redline 5w30.
I'd say it sounds like lifters, but your histology suggests exhaust. It is rare to change to 0w40 PUP and have no relief, it could be too far out of tolerance for oil to correct, dunno. Good luck
ChevySlayer69
Maine
I would have a mechanic use a stethoscope... if a lifter has really failed you could save some $$ fixing it before it wipes out a cam lobe.
U&A
2016 3500 SRW
6.4 HEMI
Just to note,
Alabama evenings are not cold enough to make a 0W40 cause oil related problems Soley because of viscosity.
Sent while firmly grasping my redline lubed RAM [emoji231]
CunningStunt
CunningStunt
Abbeville, AL
Just to note,
CunningStunt
CunningStunt
Abbeville, AL
Just to note,
I agree, but just to clarify, i had 5-30 PUP when the noise occured. I only put the 0-40 in after it happened in hopes of eliminating it.
