Another Hemi Tick
68PowerWagon
Dayton, Ohio
2022 Laramie 3500
6.7 CTD
So this summer I noticed my truck (16' 2500 w/6.4) developed the Hemi Tick. At the time I couldn't figure out if it was the lifters on the drivers side bank or the manifold. I decided to change the oil a little early since I was pulling a trailer most of the summer. I think I was just over 5,000mi. on this change. After I changed oil the tick went away. I thought well maybe all of the heavy towing & summer heat the oil broke down early & just needed to be changed. I am about 1,300 miles into this oil change & it has started to come back. No trailer pulling & obviously no summer heat. Since new I have been using the Penz. 0W-40 with either Wix XP filter or Fram Synthetic. Any ideas why this is happening part way through a oil change cycle?
crazy jerry
WY
you talking about constant tick or just the 2sec at startup ?
crazy jerry
WY
some engines have fairly loud pcv system which makes audible ticking noise and is normal. to untrained ear it could be mistaken for lifters. also some fuel injectors make ticking or clicking sounds as normal condition. if your certain its lifters you might want to have a dealer check it
Chris8579
Spring Hill Florida
6.4 hemi
My truck 2016 6.4 has a constant tick also. Dealer said it’s normal. I’m trying another dealer and contacted ram. It’s also worse when it’s warm going to try and get in dealer next week
crazy jerry
WY
im not saying you dont have a tapping lifter but most people dont know what theyre listening for. lifters are more of a tap sound. not a crisp tick or click. like i said, theres several things in the engine bay that click as normal operation
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
My truck has about 12,800 miles on it now and I've had clatter of some sort on cold start at least a few times for sure.
Seems like when it's done it, it's been when I've only ran it a few minutes to move it out and then back into my shop to make room. Then the next morning it clattered on cold start. If I run it normally, to work and back, it's quiet the next morning.
Even with this sometimes it does not clatter on cold starts so I'm not sure what is going on. It's so infrequent. im not worrying about it right now
Most of the time it's quiet. I've been using a MOPAR oil filter on it since new. I wonder if they have a silicon ADBV?
I've been thinking about going to a fram ultra the next change.. but still not sure yet. PUP 0-40 since new also. Obviously I don't put a lot of miles on it so I change oil annually regardless of limited miles.
Halligan
Massachusetts
I've had the same issue/condition on both my 6.4 and my previous 5.7 and I attribute it to the oil filter. My rational is similar and the quick start truck, move truck, shut off truck situation does not heat up the oil enough to make the ADBV pliable. I think once the truck is shut off the valve is sort of stuck in the open position and you lose the prime in the oil system. Next time you start you have lifter clatter until the system re-primes itself.
CVX20
Ont,Ca.
2019 Classic Express
X2 on the oil system bleeding down.
RamCares
n/a
n/a
Hi Chris, We sincerely regret to hear of your trouble. If it would be of interest, we'd be happy to learn more details regarding your dealer's findings to determine how to best assist you at this point. Please follow up with us via private message when you can.
Rob
RamCares
RamCares
n/a
n/a
Hi GsRAM, Sorry to hear you are experiencing this concern, we certainly understand why this would be concerning. If you end up addressing this with your local RAM dealer, please let us know via PM. We'd be more than happy to provide you with an additional layer of assistance for that process.
Rob
RamCares
Chris8579
Spring Hill Florida
6.4 hemi
Tick got worse took it to jim Browne in Tampa about a week ago. They were great. Admitted there was a issue right away checked exhuast manifolds no leaks. They diagnosed as cam and lifters. They replaced just the drivers side lifters and camshaft. Even though they originally told me they were doing all of them there was a miscommunication between tech and service writer. Because Chrysler will only pay for what they can prove is wrong. I’ve had it back about a week it sounded good when I picked it up. The tick is starting to come back though. I’ve proubly gone 400 miles.
Dodge 1500 4X4
Rochester, NY
Should of replaced all of the lifters especially with that new cam it may have wiped out another lifter roller.
Chris8579
Spring Hill Florida
6.4 hemi
Yes they should have. That’s why I stressed that to them so when they told me they were doing all my was happy till 2 days later I figured out they didn’t then 3 days after it started ticking again but not as bad. They just wasted 14 hours and maybe another cam. My old cam looked ok had minimal wear the lifters failed internally weren’t holding pressure and staying pumped up
