ibedoughboy
I know lifter tick has been discussed to death on the forum. I've had now 6 4th gen hemi rams (all with varying levels of lifter tick) but this one is new from my experiences.
Truck is a 2014 2500 4x4 5.7 with 76k miles purchased at 61k miles. It's been in warm weather GA and SC it's whole life. I've done 3x oil changes at exactly 5k miles with Valvoline synpower 5-30 and Mopar filters. Truck uses no oil over 5k miles and tows frequently. I've had Blackstone analysis done with all 3 oil changes and they show slightly high silicon (but decreasing with each change) but all other checks are good including metals and TBN. Truck was a previous farm truck with questionable maintenance. It shows 767 idle hours and 2498 driving hours and runs great.
I have only heard a lifter tick on this truck maybe 5 times on start up for a few seconds in past ~2 years/ 15k miles. Today, I started it (no noise) and drive 45 min to work on the highway and I hear a lifter tick when I pull into the parking lot and I shut it off. I know the difference between the lifter tick and exhaust tick since I've already replaced the exhaust manifold gaskets on this truck because of that tick. I have no idea when during the drive it started ticking. Oil pressure is indicating 52psi on the display, oil level is good, I restart and it's still ticking away. I shut it off, go to work, come out an hour later and restart it. It ticks for a few seconds then goes away and I drove it home without the lifter tick returning. It sat for 30min at home and I restarted it and it ticked again at start up and went away after a few seconds.
I guess the question here is, has anyone experienced the lifter tick just starting out of the blue when the truck is warm and driving and then going away?
My worry here is that in two weeks I need to drive 650miles to pick up a 6k lb camper to tow home. I really don't want to be in the WV mountains and have the top end give out.
