scnautique
- Oct 11, 2014
- 62
- 17
- 2012 Ram 1500 ST 4x4
- 5.7 Hemi
Hey all. I just picked up a 2012 1500 with the 5.7 (this is now my third 4th gen truck lol). I will tell you that it is incredibly hard to find ANYTHING else other than the 'Hemi Tick' and the exhaust tick issue when searching through the forums and Google so sorry in advance for yet another knock/tick thread about the Hemi.
I will say that I am very familiar with these trucks. Two out of three 4th gen trucks that I have had now have done this to some extent at idle - it's a slight knock and a tad bit of a rough idle. My 2013 did it (bought it used with 20k miles), my 2014 did Not do it at all (bought that one brand new and maintained it myself till about 60k miles) and now my 2012 does do it (bought used with 85k miles). It is not manifold bolts or an exhaust leak, I just had all manifold bolts replaced and have dealt that problem multiple times on these trucks so I'm positive it's not that.
It only seems to really happen below about 800-900RPM, and worsens the lower the rpm gets. I've done pretty much everything I have been able to find on the Forums - I'm running Pennzoil platinum with the rated weight and Mopar filter in it right now. Just added Lucas oil stabilizer too. I've also cleaned the throttle body, replaced the intake related sensors including the PVC valve (I was thinking that the slight shake was coming from a vacuum related issue), did all of the spark plugs, ran 91 octane - no luck. No codes or anything. Truck kinda shakes a bit at idle too. Appears to be coming more from the driver side fenderwell area than the passenger.
Anyone else's truck do this? Any suggestions? Runs great, plenty of power - I just put 600 miles on it and towed a heavy load about 100 miles with no issues. Noise hasn't gotten any worse or better.
Here's a video I found that is very similar to what I'm hearing. Any input/experience appreciated!
