Antifreeze........such a simple thing.......But can not find MS.90032
2019RamInSC
South Carolina
I messed up and left my radiator cap loose.....Ugghhh. How did I do that. WTFO!
Chrysler Material Standard MS.90032. No problem..........
Problem! Not available in any auto parts store. Online, different MS numbers. Ughhh again.
Okay call the dealer, they got it yippeeeeeee. Problem. Not MS.90032. So I asked them what do you put in 2019 Ram 5.7. Not MS.90032 it seems...........Fuughhhhh:boxed:
Stood around the parts department for an hour while they huddled.
Finally a tech came out and said. Number was changed and I should use this #. Did not even bother to take it down. I WANT MS.90032!
Left and called RAM CAressssssssssss. They have no idea, but will research and call me back. At least they got me laughing. Right call me back.
So, I searched the forum and found this from 4 years ago.
"1 Gallon - 68163848AA (concentrate) 68163849AA (50/50); MOPAR® Antifreeze/Coolant 10 Year/150,000 Mile Formula OAT (Organic Additive Technology) or equivalent meeting the requirements of Chrysler Material Standard MS.90032"
Is this still valid? I need a part # to get the dealer to order it or I will find a source on line. Or if anyone has a source I would appreciate it.
Thanks!
crazykid1994
The number was updated. Still the same stuff and still compatible with your truck. I just used the new stuff in my truck. As long as it’s the purple mopar coolant you’re fine.
kad
Hudson Valley, NY
5.7L HEMI
68163848AB is what I used in my 2014 when I needed some about 2 years ago. My dealer had no problem handing me the correct product, no huddling or tech needed. All they asked was if I wanted concentrate or pre mixed. (Then again, the parts dept at my dealer is also the only department with any true skill and knowledge.)
Also, MS.90032 is a standard, not a part number.
-K
2019RamInSC
2019RamInSC
South Carolina
-K
Ok does the container of part
68163848AB show that it meets the MS90032 SPECIFICATION?
I saw that part# on line. It showed a different MS #.
Link???
2019RamInSC
2019RamInSC
South Carolina
The bottom line at this point is that.
I cannot find a container of antifreeze/coolant that specifies MS90032 FOR SALE ANYWHERE.
As per my manual And Ram website.
2019RamInSC
2019RamInSC
South Carolina
I appreciate your response. But I am not going to depend on color. When it comes to a problem. Color won't be a defense with warranty.
I want the container to show MS90032 Or a change in writing from Ram.
I have been burned before by car manufacturers.
Thanks again.
chri5k
USA
Diesel
In all likelihood you won't find it. MS-90032 was an old designation for 10 Year / 150K mile OAT coolant that was not embittered. For safety reasons, an embittering agent was added and a new designation was given, MS-12106. This agent does not affect the coolant in any way other than making it taste very bitter as opposed to the normal sweet taste. If you absolutely insist on having the non-emittered coolant, you will have to call around to see if any dealers still have any NOS of coolant with the old designation.
Deeuubee
NY
Mopar 2020 VEHICLE LUBRICANT & CHEMICAL CATALOG
Page 4 -
Part # 10-Year/150,000-Mile - 1 Gal. - # 68163848AB
50/50 Prediluted Antifreeze/Coolant - 10-Year/150,000-Mile - 1 Gal. #68163849AB
2019RamInSC
2019RamInSC
South Carolina
Thanks for the info.
Do you happen to know when that change took place??
Here is what I am working against. Maybe to my detriment ughh.
My manual calls for MS.90032
RAMCARE customer service says I should use MS.90032 But they cant tell me where to get it Ughh.
and the Ram Web site says MS.90032
If I could see that info in writing somewhere that I should use MS-12106 I would be happy to.
I know I am being particular. I don't want to fight another warranty issue. Ever again!
2019RamInSC
2019RamInSC
South Carolina
Page 4 -
AHUH I saw your posting last. Looking at that catalogue now.
Lets see if my brain can handle it. I have been fighting a stupid computer problem all day. Tired.......
Thanks for that info!!!!!!!!!!
2019RamInSC
2019RamInSC
South Carolina
If it's mainly the warranty you are worried about, why not just have the dealer add what they use, keep the receipt and mosey on?
That is very logical. And a good idea.
But if they are wrong and I get a screwed up cooling system. Yes maybe they will fix it. Maybe. But I am still stuck with the hassle.
Anyway thanks for the response. I have not looked at that catologue that
Deeuubee
sent above.
2019RamInSC
2019RamInSC
South Carolina
Ok OK, You guys convinced me:p
And I found a dealer that took the time to research it and will print it out the documentation for me.
Thanks for all the info and help and putting up with my being errrr Slightly **** hahaha:favorites37:
Deeuubee
NY
Great, don't forget to post it back for us other **** retentive folks :)
Fitz-0518
Veteran 66-68
Central California
2018 2500. 2018 1500
2019 RaminSC is not being ****. Just common sense wise. This is a true reflection of FCA/RAM ignorance. Cannot find MS90032. I have recently purchased this from 3 sellers on line including MOPAR. Each represented on their website that they were selling and shipping MS 90032. Each came in with MS 12106 on the label. All claim "same thing" All claim that the PN 68163848AA (concentrate) 68163849AA (pre mix) is the correct controlling number. Each agreed as did my service manager that FCA/RAM owner manual statement and website says we must use MS 90032. They claim the warning regarding mixing is not referring to these two material standards numbers. They all claim it should say one of the above part numbers. Ignorant and stupid.
OP would appreciate you posting what documentation you got. Fitz
Octane
U S.A.
I buy my 10 year oat off amazon for $26 bucks.Full concentrated. Add distilled water and make it two gallons, for $13
2019RamInSC
2019RamInSC
South Carolina
I bought the "new" stuff at my local dealer. Looks the same. Not that it means much lol
My tank is now full.
Thanks again everyone.
