Any idea what this does?
Tach_tech
5.7L HEMI
That is the sensor for the automatic windshield wipers.
mjd91
San Marcos, TX
The sensors for auto headlights and auto wipers are in the ********* box (bottom right of pic in post #1) and directly on the back of the mirror.
Tach_tech
5.7L HEMI
I was on my phone before and only saw the bigger black box behind the mirror, the rain sensor is behind the ********* box. The little one by the headliner is the humidity sensor, if you have the auto temp hvac then you will have the humidity sensor.
The humidity sensor is used in order to maximize the dehumidifying effect of the A/C.
Am3gross
VIRGINIA
HEMI 6.4
Well hopefully you got the answer to your question. I know for a fact it is not the remote start because I just installed the OEM remote start and the antenna is in the headliner in the rear.
regularcab2500
Buffalo
5.9 Magnum
Again, then why does mjd91 not have the box? He claims he has the auto hvac funtion. The only explanation in this case would be that they moved it for 2014. My truck is a regular cab so i cannot have the fancy air bs but i know the wiring for the remote start is in the front for me.
C
clawwd
I appreciate all the replies guys.
I will go with humidity sensor lol
mjd91
San Marcos, TX
I think you're the only one paying attention. Lol
Edit: unless like said below, it is an addition to the 14's.
Tach_tech
5.7L HEMI
Because the 2013s don't have the humidity sensor, as far as I can tell with my service information, it was added for 2014 models.
regularcab2500
Buffalo
5.9 Magnum
Right on, glad someone actually found a straight answer lol.
92GreenYJ
Spring Valley, CA
Mine was actually missing the cover when I bought it. There is a small fuse under the cover. Not entirely sure what it's for though.
Akgiauque
Palmer AK
2015 2500 Megacab
6.4 L
Maybe it's a gps tracker from your bank, so they can find the truck if you miss a payment.
KB Sabre
Minnesota
2015 Laramie
I believe you're right. You can see a sensor pressed against the windshield.
The Q
South Texas RGV
2014 Sport R/T
Yes, that is the rain sensor. BUT, the OP is asking about a device mounted higher on the windshield! The "Rain Sensor" and "High Beam Sensor" are both mounted in a box behind the mirror.
KB Sabre
Minnesota
2015 Laramie
My mistake. I looked at it too quickly.
Could it be a humidity sensor then... Someone call Dodge!
Tach_tech
5.7L HEMI
.....It's the humidity sensor, this was answered on page 3. It was first introduced on the 2014 models.
Tach_tech
5.7L HEMI
correct.......thier either on the windshield or behind the bumper or grill
The humidity sensor won't be mounted outside. It's purpose is to help improve dehumidifying of the HVAC system. The ambient temp sensor will be outside, they used to be behind the grille, but now they are part of the driver side exterior mirror.
TheM4rxxx
