- Aug 14, 2018
- 4,161
- 3,776
- Location
- ASTON,PA
- 2012
- AK Trucks Tuned 5.7
Thank you. It’s a customers truck. My shop specializes in Rams.Man, you're truck looks perfect with the 5-inch adjusted lift and 36s on -18MM offset wheels too! Since you dialed down the coilovers, how does it ride? I am wondering if the taking the preload out of the 2.0s made it noticeably looser on higher speed turns and/or too soft for off-roading. Finally, can you get any measurements to top of shark fin with your setup as I am really thinking I could live with just 2 more inches of height over my 3-inch Dirt Logic system if it would still fit in the garage...lol.
My problem is that I wanted to go with the Fox 2.5 coilovers as that would be a nice step up from my current Dirt Logic 2.5s (especially for varying off-road scenarios) but going with a Fox 2.0 would be a step down (from an off-roading perspective). So I have been talking with the BDS/Zone techs and they said that they didn't have a Fox 2.5 coilover for their 4-inch lift and not sure if they ever will; however, a notable vendor on this site suggested that Fox is actually developing one but had no idea when they would be offered! I even asked BDS about dialing the 6-inch lift with Fox 2.5s down to 5-5.5 inches and they said that they couldn't recommend that either since they never tested it. I am wondering if dialing down the 2.5s that much would make the suspension too soft for higher speed handling and off-roading, but if the 2.0s are working just fine for you then maybe that's the answer!
AGAIN, NICE WORK!!
This set up is just shy of 7’ to the shark fin. 83 13/16”
Is your truck a 5th gen?
