Eric R
Hi RF - I just bought a 2013 Express RCSB in True Blue. I bought this with the intention of using it as a truck, i.e. daily beater/haul stuff/tow my project car(s), etc. Sure, I'd like to lower it for looks, improved handling, and easier ingress/egress, however, I'd like to maintain a good ride, and I definitely want to maintain the utility. I don't really care for the leveled look, I'd like to maintain a slight rake.
My first thought was to go for a 2/3 kit, however, after further investigation it seems like (1) most the pics of the 2/3 kits installed looked nearly identical to the 2/4 kits (i.e. more 'level' than I'm looking for) and (2) it seems like that extra inch from 2" to 3" in the rear opens the door to many potential geometry issues that require a larger investment than I'm looking to do to the truck (at least at this time).
What's worse, the previous owner installed a ~2-3" front lift to level the truck (so it's actually a little higher in the front than the back). I hate it so much. But rather than just ripping it off and having to re-align the truck, I'd rather just do it all at once.
I've been considering:
I'm having a lot of difficulty visualizing a 2/2. I've been looking for pics (looked all through the Lowered 4th Gen Pics friend and didn't see any). Does anyone have any pics of a 2/2 setup, preferably on a RCSB?
Thanks,
Eric
- McGaughys 2" Front Drop Spindles (with stock springs/this'll maintain the stock geometry)
- I understand there's a concern of adding to the front track width, but I'll likely switch to higher offset HellCat style wheels which would normally require a spacer anyway.
- Crown/GF/?? 2" Rear Drop Springs
- Any brand recommendations here? I'm concerned that being a RCSB the 2" may only be ~1.5", which makes me wonder if I'm better off finding 3" drop springs for a Quad Cab and maybe they'll only lower it ~2.5"? Does anyone have any pics/experience with similar setups?
- Bilstein 4600 Series Shocks Front & Rear
- Is there a better option for the rears? I feel like even at 2" you'd want a shorter shock
- Air Lift Rear Air Bag Helper Springs
- I bought the truck to tow with....
- (Optional) Adjustable Rear Sway Bar
- It looks like my truck never came with a rear sway bar from the factory
- Other thoughts? Do I need to mess with the panhard rod, control arm relocation kits, or shock relocation kit at 2"?
Thanks,
Eric
