Help Support Ram Forum by donating:
  1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Anyone Know How To Remove This
Discussion in 'Exterior' started by WhiteNBlackRam, May 19, 2020.
Sponsored By: BAK Factory Outlet
  1. WhiteNBlackRam
    WhiteNBlackRam Senior Member
    441
    40
    May 4, 2017
    Southern California
    Ram Year:
    Engine:
  2. Dantheman
    Dantheman Senior Member
    348
    106
    Aug 13, 2014
    South Carolina
    Ram Year:
    Engine:
    If it’s the same as the 2012, it just pushes out the front. Gotta kinda squeeze the top and bottom together then push it forward
  3. McBroom
    McBroom U.S.Marine Veteran Retired 88-2000 Military
    49
    5,404
    6,443
    May 25, 2017
    Denison Tx
    Ram Year:
    Engine:
    Hemi 6.4L
    Snaps in doesn't it?
    Blue Mule
  4. Elevated 2013
    Elevated 2013 Senior Member
    45
    948
    697
    Feb 24, 2019
    Huntley, IL
    Ram Year:
    Engine:
    There are little latches around the back side of it that you have to pinch and pull out. If you lie on your back under the truck you’ll see them easily. I think there’s 4-6 of them around the edge of it.
    McBroom likes this.
  5. kad
    kad Senior Member Supporting Member
    2,121
    1,628
    Jul 10, 2017
    Hudson Valley, NY
    Ram Year:
    Engine:
    5.7L HEMI
    This
    I had to remove mine to cut it when I put my tow hooks on (sport bumper, not factory meant for hooks) . It was a pain to get out and an even bigger pain to get back in with the hooks in place, but it's doable.
    -K
  6. WhiteNBlackRam
    441
    40
    May 4, 2017
    Southern California
    Ram Year:
    Engine:
    This is all I see when I go underneath. These white tabs. There like 18 of them. D992E227-0465-4F73-AC65-F9A5ED739C4F.jpeg
  7. kad
    2,121
    1,628
    Jul 10, 2017
    Hudson Valley, NY
    Ram Year:
    Engine:
    5.7L HEMI
    That looks familiar. I knew I remembered it being a PITA. I think I used a small trim removal tool out of my 3000 piece set to release each one. A small flat screwdriver would probably work as well.
    -K
    McBroom likes this.
  8. Elevated 2013
    45
    948
    697
    Feb 24, 2019
    Huntley, IL
    Ram Year:
    Engine:
    Those are the tabs. They can be a pain but you need to push them all out of the slot they are in and then work the entire piece out. It’s not a fun piece but not impossible to get out. Sorry. I forgot there were so many.
    McBroom likes this.
  9. JB1
    JB1 Senior Member
    7,981
    6,691
    Nov 3, 2011
    Houston, Texas
    Ram Year:
    Engine:
    ^^This
    The white tab is part of the bumper, the piece your removing has slots and removes inward toward the suspension not outward. I think I had one hand on the outside pushing inward while other hand pushed up/down on clips and just kinda worked around the edges till it popped off each clip.
    McBroom likes this.
  10. dpinvidic
    dpinvidic This guy gets shotgun
    156
    43
    Dec 18, 2013
    Cave Creek, AZ
    Ram Year:
    2014 RAM 1500 Limited
    Engine:
    Your truck is a 2014. Plastic could be a little brittle. I suggest a hair drier to get the tabs heated and hope they will bend easier rather than break.
    Shiva likes this.
Share This Page
