Anyone level a 25 1500 rebel?
ivey_usmc
Austin ,TX
I'm purchasing a 25 1500 rebel soon and want to level it. I was thinking 5100's and control arms but wanted to see if anyone has experience with this setup on the 25's.
CanuckRam1313
Ontario Canada
2023 Warlock
5100's all around and reusing the stock springs would work nicely.
If you set the fronts to 2.1" raised you'll not need UCA's (only required if you go higher than the 2.1" raised setting).
You'll have a very slight rake forward with this configuration; almost undetectable.
If you go to the 2.8" raised setting on the stock springs all around you'll have a slightly higher front end with some rear squat.
All depends on how much you want to spend to get the look, stance, and feel you're hoping for.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
all the suspension remains the same on the 25’s the steering knuckles are different and they have an external abs sensor instead of one integrated into the hubs.
Pro tip: anything 2” or above you’ll want to raise the rear at least 1”. Anything 2.5” or above it’s recommended to get an angle correcting upper control arm
