Anyone running zone UCAs on 6” lift?
Davidwalz3579
New Hampshire
I have a 6” Pro Comp lift and am getting a slightly negative camber after alighnment. My guy at the shop said it’s maxed out and still has a slight negative camber.
Anyone running Zone UCAs with similar lift? Just asking because I thought these lifts were made to run factory UCAs.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Pro Comp kits are designed to run stock UCA's we'll need more info such as an alignment sheet. Do you have height adjustable front struts/coilovers etc.
Nick@GotExhaust
Preferred Vendor
SC
What front struts are you running? If you are running an adjustable strut or coil over up front that is lifting/leveling the front then that could be the cause.
Davidwalz3579
Davidwalz3579
New Hampshire
No it’s factory with the big spacer that came with the lift. I’m shopping to upgrade to foxes or vertexes and eliminate the huge spacers and I figure I might as well replace the upper and lower control arms as well if I’m swapping coil overs already. I’ll look for the alignment sheet. Would running zone UCAs be possible on the pro comp lift and would there be any benefits over stock?
txram956
