redman4455
Well, bags will certainly help overall, especially with the rear sag and headlights in the air, but they will not realy help all that much with the front end lifting up.
And I agree with mcboom, a longbox would be much better suited for the task I think. Much depending on how large of a unit you will be using.
I'm learning with TCs is that there isnt a lot of gray area. It doesnt take much to throw you into dually territory. I'm trying to stay in the 3.5k wet weight srw short box arena. If I go long box, I will likely end up with a dually since my selection if TCs increases dramatically.
As for the TC causing front end lift, wouldn't that also cause a headlight up issue? I would like to avoid lifting all together due to instability on COG. Chances are, the TCs that are too light are too small as well. I may end up with a dually lol.
