Anyone try Modifystreet headlights?
randerson0248
Northern California
OK. I now have alphaobd. What would happen if I chose the wrong MY for the body computer? I have a 2019 Classic. Here are options that show up below MY2013-2017 PowerNet:
MY2018 PowerNet
MY2019 PowerNet
MY2020 PowerNet
then 5 more that start with DT MY2019 and DT MY2020
I guess I should use MY2019 PowerNet. Can someone confirm? Do not want to mess up my first alphaobd change.
SitKneelBend
St. Louis
3.6 Pentastar
MY2018 PowerNet
MY2019 PowerNet
MY2020 PowerNet
When I choose the wrong one it reverts to My2014 (which is what I have).
Blstrick55
Everywhere
Has anyone run into issues with the Alpharex headlights burning out bulbs? My driver side headlight is having issues with led bulbs. I'm on my third bulb and first symptom is it starts flickering then it will stop working intermittently then it goes out completely.
1500ram12
5.9L Cummins
What bulbs are you using
2018 2500 6.4L Hemi Tradesman
1990 5.9L 12v Cummins W250
Blstrick55
Everywhere
First Hikari, then Aukee now I'm trying a cheaper brand with good reviews on Amazon (Car Rover) because I got tired of paying $50/pair.
Mbrigh3
IG: Stormtrooper_5.7
MD
I have both brands listed above 0 issues. Sorry for your luck
Sent from my SM-G998U using Tapatalk
1500ram12
5.9L Cummins
Hmmm. The wiring for the high/low is really basic, just like oem quads. I'd start by checking the best you can the headlight wiring, connector at the bulb, at the headlight-truck, then inspect the truck's wiring by the headlight. Then if you have or have access to a volt meter and check voltage
kegger
3.6 pentastar
I'd say it's something to do with the truck rather then the bulbs to be honest. I've been running hakari LEDs in my alfarex pro series G2s since I put them on the truck and haven't had issues. Sucks that it's blowing led bulbs, they definitely can be expensive to be replacing all the time.
Sent from my SM-G975W using Tapatalk
Mpgrimm2
Preferred Vendor
SC
2022 Ram 1500 (5th Gen)
5.7L
Did you use AlfaOBD to set the BCM for HIDs so it would disable the pulsed 12v (PWM) to the lights?
M² Mods.
VLG6963
