Are the Headlights in MY22 Laramie upgradeable?
mikeru
Super Moderator
Super Moderator
Eastern WA
2020 Limited
I can't answer that for sure since I've never used AlphaOBD, and am not familiar with how they work. Maybe someone else here can answer that.
turkeybird56
Central Texas
Dont think you can, those are sealed up. No way to do it, unless you break them down and heat them to pull the lenses off.
May be AlfaRex or Morimoto have a compatible projector style. I thought the reflector LEDs are supposed to be better than average.
THEY are a heck of a lot better, I have Level II LED's which are reflectors. I will never go back to Quads/Halogens. BUT they R sealed units. One of my rear tail lights was cracked which I had replaced under warranty, and U really do not want to know the Dealer price on that item.
Hello All,
So like usual, the headlights on my new 22 Laramie 1500 are pretty crap. Even the high beam is not real bright. But having a look inside, they look like LEDs and I am now wondering if they are as good as it gets? :(
I have noticed LED upgrade stores online don't have my truck listed.
Any info you can supply would be awesome.
Cheers
J
To help, post a pic of the front of your truck with lights on and off, may help some members to furnish info.
turkeybird56
Central Texas
Oh wow, that really sucks.
Will my AlphaOBD software work with 5th gen also?
U have to get a security bypass cable for the 5th Gens. Not sure ref U need an unlocked PCM or not as I do not have AlphaOBD. U would have to go to the Alpha OBD thread and post that question.
Dodge 1500 4X4
Rochester, NY
What you got is as good as it gets, I have a 2019 Laramie with the LED automatic reflector headlamps, and they are bright enough for me, I talked to a headlight expert, and they are a sealed unit at the cost of 1,200.00 per side.
