Aries steps installed!!??
GlOcKnRaM
Mebane, NC
5.7L V8 Hemi
So I purchased a set of Aries step bars for my truck, and I finally installed them today. They arent bad steps for the price, but I ran into a few problems. Since I have a body lift they kind of dont look right. They hang down a little to low and I couldnt use the supplied hardware because the bolts werent long enough, no big deal I just used the ones from the body lift kit. Like mentioned from the site reviews they arent really the ones shown in the picture and they dont seem very durable. Instructions were a little iffy as none of the parts were labeled right/left. I will run these for now, but the next ones I get need to be mounted to the body/panel and not the body mounts..that way they will be up higher. Ill have to do some research to see if the Go Rhino ones get mounted to the body(like the oem steps) instead of way down on the body mounts. Overall I like them and Ill run them for a while! Not a bad step for the price you pay($170)!
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Steps look nice, but I would definately try to fab up a bracket to mount them up closer to the cab. Do you have a picture of how they mount to the frame?
GlOcKnRaM
GlOcKnRaM
Mebane, NC
5.7L V8 Hemi
Well looking at them I could always cut the brackets, make new mount holes for the bars and that would raise them up. Id want to raise them up about 2". Ill take some pics of how they are mounted.
Liquidoxygen
Edmonton Alberta Canada
2500 Diesel
Great lookin truck man. The bars don't look right at all they are Way too low. Looks odd but if they are functional then they are ok for awhile right?
GlOcKnRaM
GlOcKnRaM
Mebane, NC
5.7L V8 Hemi
the front ones are also supported with these braces
Id have to get my hands on a plasma cutter as the metal is pretty thick and Id have to cut a new hole where the steps mount through. Id like to cut about 2" off and move the mount hole 2" up which would raise the steps 2" up.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
That looks like a very easy fix. Just cut 2" off the bottom of the brackets, drill a new hole like you mentioned for the steps to bolt to, and you are good to go. While the steps themselves look nice, I would get on fixing those brackets ASAP...haha.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Before you do any cutting, I would unbolt the steps from the brackets and then have someone hold them in place where you want them to set. Then make a mark at the bottom of the step where it touches the bracket so that you know exactly where to cut. You dont want to get greedy and cut off more material than you need.
GlOcKnRaM
GlOcKnRaM
Mebane, NC
5.7L V8 Hemi
Exactly what im going to do, they look kind of stupid right now haha..once I make this fix happen then they will look right!!
BigSexyBlue05
2012 dodge ram quad express
I have the Go rhino steps. They are mounted to the body.
GlOcKnRaM
GlOcKnRaM
Mebane, NC
5.7L V8 Hemi
I was just talking to Bighorn4life about this lol..Im going to cut/fab them for now, then invest in some Go Rhino ones! You wouldn't happen to have any pics of them on would you?
quietpeen
2021 TRX
Hellcat
They are nice but I agree they are a little low
jasf
NY
I just got the same ones dropped off by UPS. Planning on getting the install done tomorrow. Will try to post pics of them on a stock truck. Opening the box I got what I expected for $170.
The look good to me. Perfect place for an actual functioning step. Bad if you wheel, but good to aid all your girlfriends to get in your truck.
GlOcKnRaM
GlOcKnRaM
Mebane, NC
5.7L V8 Hemi
I think on a stock truck they would sit about 2-3" higher, my body lift makes them sit low like this...so I think ill raise them a tad!
jasf
NY
Got mine on today. To dark for pics. They're OK for the price. Driver side bar is tight as a frogs ass,but I cant get the pass side to not have a little wiggle. The install is a PITA!! The kit includes 4 different front braces & none of them fit right.
jasf
NY
Here they are on a stock truck.
GlOcKnRaM
GlOcKnRaM
Mebane, NC
5.7L V8 Hemi
^^Thanks for that man..thats exactly where I want mine sitting, after I fab them up!
GlOcKnRaM
GlOcKnRaM
Mebane, NC
5.7L V8 Hemi
Well I finally got around to fixing my steps today. With my dads help we raised them up 1.5". Before we cut or drilled we held the steps in place to see where they looked right at/worked best at. They wound up needing to be raised 1.5" to be right so thats what we did. We cut the brackets, drilled new holes, painted the brackets and re-installed the steps. They definitely look right now, so here are some before and after pictures. I have some during but you guys know what cutting and drilling looks like haha.
Before:
After:
Sorry for the dirty truck, got some snow last night so its a mess!
stevenmicheal
