Thanks for updating this, I had semi forgot about it because it took so long. The numbers were disappointing, but its easy to see performance was not there main goal here. I mean setting up a gas 3/4 ton for performance/racing is obviously not the best platform, but I imagine that one of these trucks could see some decent power with a more aggressive set up. Honestly for 6psi, that's a huge waste of time and money.
The numbers I saw on the stock turbo Cummins mentioned above, were 100 less on both. 430/1100 but I may not be up to date. Either way, its impressive.
I was just thinking it would be cool, and interesting, to see what adding 150hp does to each platform. Seeing as they are about the same speed stock, it would be interesting to see how they compare from a straight unloaded acceleration contest.
I'm curious to see if whipple and procharger produce anything. Whipple diddnt sound too confient, but procharger said its so similar to their existing kits it wouldn't require much change and that they have actually had some interest in it. Could be cool.
It would be cool to see a similar power potential for the gas trucks, for those who don't want a diesel for whatever reason. Because realistically, a lift pump, deletes, exhaust, tuner, intake, sump kit, head studs, etc for the diesel adds up quick $$. If you could slap a blower and headers on the gas truck and make 500, it would be cool to see. Like a 500whp power wagon on 35s
