Arrington Performance
Kelli25
Does anyone have any advice on who to talk to at this shop? :shrug:
I haven't had the best of luck so far...:emotions33:
In case it is relevant, the subject would be my 2012 RAM R/T.
Thanks for any possible help. :ehcapt:
HLram
2012 and 2007
Hemi 5.7 in both
well..... if you aren't having any luck getting ahold of them, then probably finding a different shop might be better for you because that is probably how they will take care of you after you become a customer. Just my opinion.
charonblk07
Calgary, Ab
F1-A forged 349ci
I always dealt with Don, but he moved to HHP, after that I worked with Alex who was good. What exactely are you looking to know?
Hemi_Express2013
Nantucket, Ma
If you are customer, then you have your sales guy. Customer services is rough there. I always, and I mean always go with AJ in the tuning department for anything. They have opened another shop in NY, truck is going in at the end of the month. Hemituner can be found on MMF among other places.
K
Kelli25
Thanks everyone.
Let me give the actual situation. Im sure having all the info will help you to help me. Maybe someone can give some advise on where else to go.
I drive a 2012 SCSB R/T. I originally wanted to do some sort of forced induction and be done. Only to find out that tuning was an issue (at the time) and I couldn't go that route. So I then tried everything under the sun to get the most performance out of my truck. Long tube headers into high flow cats. New y pipe, cat back exhaust, lower t stat, Cold air induction, larger ported throttle body, torque converter, I even changed to royal purple oil and put on a catch can. By the time i got done with all of that, tuning was an option. So I got a custom tune as well. So thats where the truck stands right now.
I decided recently that I would go ahead and finish the truck by going the way of F/I.(Its always been a dream of mine to have a truck with forced induction.)
So I had STS work me up a quote on a turbo system. Larger injectors, water/**** injection, and all that good stuff. I know it sounds crazy, but I'm not looking to go racing with this truck. I just like strong acceleration. So I am thinking about staying in the 5psi range. The whole thing including tuning, was in my price range, so I feel great about it.
But.... I love the sound of my truck. And the STS will change that quite a bit. So i wanted to see what possibilities were available with superchargers before I just jumped into the turbo.
So I called Arrington Performance (not for the first time)and when I finally got through and got someone on the line, I quickly and very pointedly explained my wants and budget to them. They were very dismissive and uninterested. Whoever I was speaking to told me they would put together an estimate and get back to me. That was two weeks ago..
I should mention that i went through that exact situation with them about 6 months ago as well. I got busy working and then didn't have the time to mess with it. Till now.
Unfortunately, this is the only shop that I have any knowledge about. I have heard that they are the best for builds and tuning ect. Otherwise i would have not bothered with them after the first time they shunned me. I wonder how in the heck they do any business at all from what i have experienced from them. I mean its not like I'm wanting to waste their time for a small gain. I would consider the budget to be substantial, by anyones measure. But lets get back on track...
So my goal here is to simply speak to someone knowledgable on the subject so that I can weigh the pros and cons and make a decision. STS was very helpful and enthusiastic. Would be great to find someone in the SC world that was of the same mind.
So If anyone has any thoughts on the subject, please feel free to enlighten me or share your opinion. Any feedback will be greatly appreciated.
Thanks again!:patriot:
charonblk07
Calgary, Ab
F1-A forged 349ci
Luckily you're part of a forum with several members who have done exactely what you want to do and if you just want to go F/I and keep the boost low then you're in luck.
Arrington does amazing work, but they spend a lot more time working the LX side of Chrysler as it's a much larger market and they are extremly busy. They get a lot of tire kickers so I can understand their attitude, I may not condone it, but I can understand it, especially if you're a new customer.
Now, if you want additional options for F/I the 2 easy ones are Procharger and RIPP as both have bolt-on centrifugal superchargers. I hate to say it, but any venture into F/I will change your exhaust tone, so if that's your limiting variable then I would give up looking now and accept the power level you're making. A turbo will defintely be quieter than the supercharger, so at least with a SC you can work alot more with the exhaust tone unlike with the turbo.
What kind of budget are you looking at for this project? For me I found a used P1SC kit for $2500 that I needed to add an intercooler, injectors, MAP, piping, and tuning which worked out to just over $4k with me doing the install. A new kit would've run me $6500 and I could have bolted it in and be done. You can do things on a budget if you take the time and be patient for good deals.
ericlee9386
Thanks everyone.
If you don't mine me asking how much was the sts package? I take it that it was a rear mount after the y pipe?
Hemi_Express2013
Nantucket, Ma
My suggestion would be get your local performance shop with a dyno do the install and have Mike or his son Micah @ OST do the remote tuning. $700-800 with something like 10 revisions. Really good people. HHP will do remote tuning, contact Don, formally of Arrington. and Johan Mangs(diablotoona) will do the same for a donation of $200-700.
K
Kelli25
Im shocked they do any business at all if that is how they do things. But, thanks for the heads up.
It was my understanding that the turbo simply replaces the muffler on an STS package. At least thats what I was told. Im not so worried about changing it as I am REPLACING it.
I was actually looking more for twin screw type SC. I would like to get into the power a bit quicker and top end has never been my thing. But all the numbers you gave me are super low! It would be great to find something in that price range. I wouldn't say that the budget is endless, but i will be able to afford whatever choice I end up making. If you have any tips on where to look, I would be in your debt. I don't know any spots to go to.
I am patient, (been waiting for two years) but its getting close to when I need to knock this out. I will be getting busy again soon, and then i can say goodbye to doing any work on my truck.
Thanks for the feedback. It certainly helps!
K
Kelli25
Man, I just moved and don't know anything about the shops in this area. Not sure I trust many people with that kind of thing anyway. I would be cool to install a S/C. My biggest question on any of it is tuning. Seems like this is still an issue. Also seems dependent upon the situation.
As far as your advise, can you explain OST and HHP and all the names you mentioned?
I appreciate the help!!
K
Kelli25
I may send my truck to them in Utah. Which is NOT close to me. The total was around 10. But that was with tuning, install, and the intercooler.
And yes on the rear mount. Another reason I was leaning towards them. Less heat than a S/C. Though if I went with a water/**** system, then I guess thats not as much of an issue.
fasthemiram12
Eagle 5.7 vvt
I'd build the motor/trans... Then think about F/I
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
2019 (2003 Forgottens SOLD and 2014 SOLD)
Hemi 5.7 (392 Hemi) 86 Ford .308 HO Roller
I vote to do the STS set-up! Good Luck with your Dream, Hemi Engines are Awesome in any form or HP level. Danny
The Unabomber
2014 Ram 1500 R/T
I don't know if you've considered going this route or not but why not toss a cam in it? If you have all the bolt on's tossing a cam in is going to really wake it up.
With all of your bolt on's and a tune your going to push 70-100 rwhp. Not to mention you wallet will be a lot heavier.
K
Kelli25
And how would you go about getting the same amount of HP that F/I would give you?
Our heads are already pretty great. And other than a cam, I can't see anything that could give me as much gain as F/I. Other than building the entire engine. Which would cost more money and much more time. Heads alone run in the 2,500 range. And thats without installation. Swapping heads is something I don't think I have the time for. So installation would be necessary. And then I still run into the fact that the truck would need to be tuned.
I will build the trans when this one gives out.
K
Kelli25
Honestly I would love to that. My issue with anything engine build related is finding a shop that can do the work/tuning.
You are totally right on the wallet being heavier. haha.
I have done a bunch of research on people with my truck (2012 R/T) that have done this and not really ever gotten the truck to tune up correctly. So my concern is doing something to the internals of my engine and then not getting the most out of the upgrade.
If I find a shop that can do solid work, I would probably have them throw a cam in it at the same time i do the F/I.
The Unabomber
2014 Ram 1500 R/T
If it was me I'd go cam and tune first. You want low end power over where you are now. Well with a cam there are spots on the curve you see 100 hp gains. The power comes on crazy.
Take a look at HHP and see what they have to offer. With most of the bigger aftermarket dealers out there they have installers in most major cities to help take care of you.
In regards to the tune issues you speak of that's more of an issue with the diablo tuner having some ***** issues with the trucks. I think most of the kinks have been worked out.
K
Kelli25
Wow. I didn't realize a cam would bring that much power to the table. I will definitely look into that... Im guessing Hemifever can tune me up. He has been on top of all my mods so far.
If i can find someone that will speak to me at Arrington, I will ask about installation spots.
It might be great to do a cam either way. At those prices...
Thanks man.
BlackRamHemi
Edmonton Alberta Canada
Wow, sucks having a 12'
My Ripp Stage III 8psi kit for my 10' Ram was $3700 after tuner credit ($300), included tuning.
Driveway installed with basic hand tools in about 6 hours. (kit, plugs and injectors)
also running AIS Water/**** kit, Custom Built trans from L&M, ATS 3k Triple disc TC, AutoMeter Triple Gauge pod
about $10k deep so far, all DIY
shaunnz
