Nathanv
I need help with my 2011 ram 1500 I just did cam and lifter replacement and got everything done went to start it and was having weird electrical issues as shown in vid I will put on, I jumped the starter at the relay because I couldn’t crank it over and it cranked, fixed two grounds and it randomly started working the electrical issues I wa having was crazy the relays were clicking on and off and everything was going nuts. It all stoppped randomly after doing the motor multiple times. But when it did run it was in limp mode with a check engine light, I had a high bank code for an intake runner position selonoid, I pulled the intake looked at the selonoid and it was like spinnning and it wasn’t doing anything at all. I replaced it with the doorman repair kit plugged it in to the original harness because I diddnt think there was a need to wire in the new one as my wiring looked fine, and I plugged it in all this weird electrical crap returned. I have it at the ram dealer and they can not figure it out either and say the selonoid is spinning weird and doing weird things and they are baffled at what’s wrong.i should also say my obd reader can’t connect to any modules, it says 0 n/a Or something and it won’t connect to anything this wasn’t happening before the sensor replacement now after replacing the sensor thing it’s not even connecting to computers
Vid of electrical crap.
