Help Support Ram Forum by donating:
  1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Audio upgrade Infinity Reference
Discussion in 'Audio & Electronics' started by Redheadhunter21, Jan 2, 2019.
  1. PowrRam
    PowrRam Senior Member
    674
    553
    May 12, 2018
    Minneapolis
    Ram Year:
    2018 Big Horn
    Engine:
    3.6L V6
    Nice write up.
    I see you have a 2018. Hate to break it to you but if you are running the 8.4 system with application software version 21.9 you're not going to get the full benefit of having the new and much better speakers. I found out the hard way. After installing Polk 3.5" in the dash with 4 ohm resistors, Pioneer 6X9 in the front doors, and a powered subwoofer, Uconnect ruined the stereo with their software update of September 4th.
    You can read about it here, if you haven't already.
    https://www.ramforum.com/threads/uconnect-software-update-received-whats-in-it.126015/
  2. Redheadhunter21
    Redheadhunter21 Senior Member
    29
    140
    85
    Oct 26, 2018
    SFL
    Ram Year:
    Engine:
    There's slot you can you hold the wires in so they don't fall but yes it wouldn't be fun trying to get them back up
    Luckily for me I added the 8.4 to my truck from a 2014 jeep so that not a problem as it's running an older update, but good info for others looking to upgrade
  3. shadowhawk
    shadowhawk Senior Member
    2,849
    2,088
    Oct 30, 2017
    Southeast WI
    Ram Year:
    2016 Sport- born 05/2016
    Engine:
    I wish I had known. My fat hand almost didn't come back up while holding the wires.
    Outbreak likes this.
  4. osprey92
    osprey92 Member
    71
    15
    May 1, 2017
    Ram Year:
    Engine:
    Yes, it really is an easy upgrade and makes everything sound so much better. I did the JBL GX302 in dash and the Infinity Reference REF-9633ix in the doors. The wiring harness adapters (Metra 72-6514 and 72-7902) make everything a breeze. Just a note, depending on your headunit and EQ settings, the resisters may not be needed. I push the balance slightly to the rear and can hear very balanced sound in all seats.
  5. Redheadhunter21
    29
    140
    85
    Oct 26, 2018
    SFL
    Ram Year:
    Engine:
    I ran them for a couple days without the resistors because I wanted to see if it would help with bluetooth phone calls. I could quiet them down some by fading to the rear but that also took the power out of the front door speakers. Plus going any higher than about 22 of volume and the dashes were maxed out and the doors had so much more to go.
  6. Soregra
    Soregra Junior Member
    48
    May 31, 2018
    Ram Year:
    Engine:
    Redheadhunter21... same speaker upgrade I intend to do very soon on my ‘14 QC. I know nearly nada about car audio.... could u give me a link to the 4ohm resistor you used in the dash? Are all resistors created equal or is there specific things I’m looking for... thanks.
  7. Rbohno
    Rbohno Senior Member
    60
    160
    136
    Aug 4, 2014
    NC
    Ram Year:
    2019 2500 CTD Limited
    Engine:
    Cummins
    I will say this just as a word of caution, I was changing all the door and dash speakers.
    I got to the rear doors and was putting the panel back on the rear door and it slipped out of my hand and broke a little piece of plastic for door handle on black panel behind door panel. Cost $479 for that black piece because you have to buy the entire panel because it’s one piece.
    So be careful !!!
    cnitty likes this.
  8. Redheadhunter21
    29
    140
    85
    Oct 26, 2018
    SFL
    Ram Year:
    Engine:
    https://www.amazon.com/gp/product/B07CWQPWCM/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    There's the link to the ones I used, you can find them cheaper just match the specs.
    Soregra likes this.
  9. atest4u
    atest4u Junior Member
    49
    May 21, 2020
    Dallas
    Ram Year:
    Engine:
    Just want to ensure I was reading this correctly, you installed the same infinity 6x9 in both the front and rear doors and only needed a 1/4 inch spacer to fit in the front doors.
    thanks
    The Gibson likes this.
  10. The Gibson
    The Gibson Junior Member
    55
    29
    15
    Jun 27, 2018
    California
    Ram Year:
    Engine:
    Would a 1/2 inch spacer have worked? I read that somewhere and ordered a 1/2 inch spacer from Amazon.
    https://www.amazon.com/gp/product/B00TQOX080/ref=ppx_yo_dt_b_asin_title_o00_s01?ie=UTF8&psc=1
Share This Page
