Auto Dim Headlight in 2020 Ram Limited
Brady Allmon
Arkansas
Hemi V8
Lights are set to Auto
Auto Dim is Turned on in Settings
Arm is pushed forward to activate bright lights
Lights will not Auto Dim with these settings! What am I missing?
JoeCo
NY
So the auto dim works properly with the low beams on, but when you activate the highs the auto dim stops working? Or does it not auto dim with any of the headlights on?
ETX Ram
US NAVY VETERAN
Northeast TX
2018 Longhorn Southfork Edition
6.4L Hemi
Light rotary switch itself is in auto? Assume that is way you mean in first sentence. Pretty sure 2018s have forward mounted camera above rear view mirror as sensor as mine will sense both oncoming headlights and tail lights being followed. Not sure about 2020 models, but assuming same setup. Don't have windshield "eyebrow" tenting do you?
All else looked correct otherwise.
Lee
JoeCo
NY
Lee
I was totally confused on what he was talking about I guess, but now it makes sense. Brady, is the truck lifted at all or leveled?
ETX Ram
US NAVY VETERAN
Northeast TX
6.4L Hemi
Well if not lifted or otherwise leveled or somehow blocked by tint, thinking would be time for dealer to check out sensor. I'm no guru though.
Lee
corneileous
Podunkyville, OK
2018 Ram 1500 Limited 4X4
Sounds like you have everything set right but as soon as you push the stick forward, the brights immediately turn on? I guess I need to pay better attention to mine but I’m pretty sure there is a slight delay from pushing the stick forward from when the brights automatically turn on.
Do you have anything blocking the front camera that’s up between the rear view and the windshield?
JoeCo
NY
Lee
Agreed, I know my leveled ram with the auto dim doesn't work great but on stock setups I've seen them work much better. So if not that, or as you mentioned, something blocking the sensor, probably would have to resort to taking it to the dealer.
chrisbh17
This isnt the first post we've had about the new RAMs having issues with auto high beams.
I have a feeling there is a bug somewhere that needs to be fixed by FCA.
corneileous
Podunkyville, OK
Mine was trouble free up until I put HID’s and LED’s in my factory projectors. The rejection off road signs is enough to make my system think there is an oncoming car so it dims them a lot for no reason.
Brady Allmon
Brady Allmon
Arkansas
Hemi V8
I’ve made no modifications to the 2020 Ram and no Window Tinting. All stock! Yes - when I push the stick forward the bright lights come on but fail to auto dim.
I had a 2019 Ram and had no problems with auto dim!
However, I got rid of the 2019 Ram because of motor cylinder #7 failure with possibility of #5 failing! The truck was still having engine shake ever so slightly even after repair. Even though I had warranty, I was tired of trips to dealer! Yes I’m giving Ram one more chance and this autodim thing, even though small, is annoying!
magic280z
2019 1500 Laramie
When you push the lights into high position does the dash briefly show automatic high beams enabled? It will say disabled if you manually engage low beams. That at least will verify settings are correct and it is probably a sensor issue.
Sent from my SM-G950U using Tapatalk
chrisbh17
If it's like the 4th gen the headlights need to be in automatic mode.
OP mentioned tinting.... Did you get the windshield tinted as well?
Sent from my Pixel 3 XL using Tapatalk
Brady Allmon
Brady Allmon
Arkansas
Hemi V8
Display does not show Auto High Beams engaged when stick pushed forward. It is setup correctly in Settings! I think it’s a sensor issue!
chrisbh17
Did you get your windshield tinted?
Jzhorseman
Mountain Home, AR
Picked up my 2020 Limited after Christmas. No Auto High beam dimming. 2015 Worked fine. UConnect activated switch forward driving over 20mph. No notification in display. Will be checking with dealer soon.
Russell Hague
Hercules CA
My brand new 2020 Limited same thing. Stick forward, hi beams only. Dealer said was functioning properly and it was up to me to program it properly. I’ll be trying a different dealership next week.
