nikwho
Hello all,
I am looking to bypass the Automatic Shutdown (ASD) Relay. I am in the process of deleting EFI in a truck and the fuel pump will not run. I am running an aftermarket distributor. I've read in the Chilton's manual that the ASD relay receives a signal that allows the fuel pump to run. Mine is not receiving this signal, as I do not have the factory distributor hooked up. I am looking for some help, if anyone has experience with this, or a wiring diagram that I can use to figure out how to artificially send the signal to this ASD relay.
Any help would be greatly appreciated!
Nik
Nik
