Aux Reverse Lighting - Let's see your setup!
Stringer
Stringer
Stockdale, PA
So I decided to crawl under my truck last night and start looking for possible places to mount my lights. I wanted to put them somewhere where they are not visible (for the most part) when looking at the rear of my truck, but capable of throwing ample light at the ground when backing up.
Once I had found the spot to mount them, it was off to Lowes for a piece of angle and two 5/16 flange bolts with washers, locking washers, and nuts.
picture.php
picture.php
Since I used the same angle when mounting my 42" bar, I knew it would be strong, easy to work with, and also easy to cut:
picture.php
I decided on using the slots on the hitch receiver since I would not be required to drill into the truck anywhere to mount. I put a piece of the angle flipped upwards on the outermost side on both sides of the truck:
picture.php
picture.php
picture.php
Once I had my brackets mounted, I took the time to assemble the mounting hardware on the light pods. Instead of having them at a 90 Degree, I faced them down just a bit so that it would shine right behind my rear tires. Once completely assembled, I took them under the truck and mounted them as far back on the angle as I could:
picture.php
picture.php
picture.php
picture.php
Notice that they are only visible when looking directly under my truck...
picture.php
...and not when you are looking at the rear
picture.php
I plan on wiring these as well as my 42" bar in my front bumper either this weekend or the beginning of next week. I also want to thank everyone who provided examples of their mounting places - it was greatly appreciated!
Wandell
Cummins 6.7
Do you by any chance know if this method will work on a 1500? And if so do you have measurements on the L bracket that I would need to use? I really don't want to drill into my bumper if I don't have to. And I like the way yours came out! Very clean look
No, I've never looked at the frame on a 1500. I made the bracket from flat stock that I purchased from the local hardware store. I just "eyeballed" it. As you can see, I made it longer than needed so I could experiment with mounting position if I needed to.
smoothee
St. John's, NL
Couple of corner braces at Home Depot. Pics don't do justice, they are hard to see if you're not looking for them.
jwheeler
Washington
How are you guys wiring these reverse lights? I just got a set of flush mount LED pods I am putting in this weekend. Was going to wire them to come on with the reverse lights and with a switch for use as camp lights or whatever. Not sure if I want them to always come on while in reverse for daily driving though.
smoothee
St. John's, NL
I wired mine to factory aux switch. I didn't want to take the chance of blinding everyone by tying them into reverse.
AustinB
Banned
San Diego, Left Coast
I really like the idea of that... Some quick details on how/where you wired it in, relay, fuse...
Only downside I guess would be turning on your cargo light for the purpose of actually looking at the cargo in your bed... While driving at night. Lol.
IMO
sbarron
Wasilla, Alaska
wired mine into the cargo light circuit so they come on with the key fob or as ******* lights while driving, also into the reverse lights so, well.. reverse.
here's how: :)
smoothee
St. John's, NL
IMO
The cubes came with a standard relay harness with Deutsch type connectors. They're a local to me company, but all the harnesses are pretty much the same.
Dual Plug & Play Wire Harness (Rocker) – NL Light Bars
I spliced both lights into one using larger gauge wire and ran everything inside the engine bay. And mine aren't tied into the cargo lights at all, they're completely on their own.
hrazz7
Houston, Texas
Creative wiring it to the cargos i have mine wired to my reverse with a switch running to the cab!
reek
Sacramento
2015 RAM 2500 CC 4x4, 72 D100, 73 D100, 01 RAM 2500 field truck
I ran a fused power line from my battery. Pulled a signal power line from my in cab cigarette lighter for a keyed accessory power that shuts off. Put a toggle switch on the little dash panel to the left of the steering wheel under the head light switch. Ran the lines through a Bosch type relay hidden under the rear seat storage area, under the carpeting. There's a plastic plug in the floor right there so no need to drill through the floor pan. drilled through the plastic pug, ran wire through a grommet and then sealed with silicone. From there ran it to my rear bumper. I didn't want it to come on only with reverse. Often use the light in my field so needed an independently controlled light. now I have LED front and rear Aux lights. Maybe I need some neon under body lights too....:joke:
btw, concerning the bumper possibly rusting. On my 2500, when I cut the bumper I did coat the cut edges of the bumper with some Por15 I had laying around from my el camino restoration and then used a silicone gasket maker to seal the area between my lights and bumper surface. Hopefully that' will help prevent rusting.
24poepoe
hem 5.7
I borrowed stringers idea and used the angle iron from lowes
reek
Sacramento
You guys gave me the courage to cut my bumper too. Had these for two weeks, finally decided to put them in.
Nice job! you have the 4 led version of the lights. how's the light output? I have the 6 LED ebay versions.
Once I accepted that there were really nice aftermarket bumpers available, it really helped me get up the courage to cut the first hole. The fear of hearing the wife "you ********" me about screwing up the bumper of a new truck helped make sure I did it right. and the promise of a few Lagunitas afterwards helped me start the second hole.
w6pea
U.S.Marine Corps Veteran
San Diego, Mexifornia
2016 Ram 2500 "Laramie" 4x2 CC/LB SRW 6.7L CTD Leer 122 Campershell
6.7L IL6 Cummins Turbo Diesel
I talked to 4 Wheel Parts, got a quote, installed Front Driving Lights, Back Up Lights, with a switch to make the back up lights Work/******* Lights. These are all Rigid Lights......$2066.25. That's a little pricey. The kid said that they needed 3 weeks to get the parts. :flipthebird:
So now I'm going to do a search, I have a friend that has a shop he said he would call Rigid and get a price for me. Then sell them to me at his cost, and all the beer and pizza he could consume to install them. (might be cheaper to have 4Wheel Parts do it)
sbarron
Wasilla, Alaska
I talked to 4 Wheel Parts, got a quote, installed Front Driving Lights, Back Up Lights, with a switch to make the back up lxights Work/******* Lights. These are all Rigid Lights......$2066.25. That's a little pricey. The kid said that they needed 3 weeks to get the parts. :flipthebird:
I was about $2K in my lights without installation, maybe a touch more, but did all the install myself. You want to save some dough, it's not that difficult if you have the tools; but it you have a friend with a shop, that's even better.
