Aux Switch Panel Placement
trdt44
Utah
So if you get these switches added you still have to program the truck that they are there??
I have found that in the previous Ram version is that they will work without the programming. The default is Aux 1 & 2 can be turned on anytime and 3-5 are ignition only. To modify this then the aux switch menu needs to be turned on. I am assuming that the '19s are going to be similar.
Maligator
Hem 5.7
From what I gather and what it looks like is the 4th gen ram electronics aux switches function completely independent of your factory wiring. The switch wires on the panel they supply run directly to their custom made relay/fuse box and to your accessories.
trdt44
Utah
That is correct. That really is the only way to do it unless a lot of money is spent and the wiring harness is replaced. On trucks without the OE aux switch option the wiring from the back of the switch bank for the switches is not there. The factory relay box (Aux PDC) is only available with a wiring harness. I have spent a ton of time reviewing wiring diagrams and parts list trying to come with a more oem solution. As I mentioned earlier I have settled on making my own wire harness and using an aftermarket relay/fuse panel. I have all the parts compiled to make a plug and play harness just like 4th gen electronics. I even found wire that matches the OEM colors.
SeaSickSailor
Hillsboro, Or
6.4L Hemi
It’s centerline under the middle of the truck. It was installed by the dealership before I picked up the truck. That and the dual battery system.
olyelr
Kewadin MI
You gotta be ******** me! Your dealer must be very much different than most of the others out there!
SeaSickSailor
Hillsboro, Or
6.4L Hemi
Well, I did have to pay for it. They also installed my White Knuckle rock sliders that I had ordered and had delivered to the dealership.
olyelr
Kewadin MI
Yea, that's frikin awesome. Please share what dealer you are using.
mtnrider
Georgia
What's that up on the dash by the steering wheel? Another switch?
Yeah, I originally only had one light bar and put a single switch there. I have since put an actuator in my tailgate and use that switch to drop the tailgate.
mtnrider
Georgia
Thats the muffler bearing switch... each time its depressed it sends a shot of fluid film into the muffler bearings.
Passenger seat ejection button, for that friend that just won't stop talking.. Lol
SeaSickSailor
Hillsboro, Or
6.4L Hemi
That was Northwest dealership in Beaverton, Or. The Parts manager, John Nees, did all the purchases and only charged me their cost. I did pay labor.
56PW17
Pa
link to a product? Does it go up and down or only one direction? Need to know more about this???
mtnrider
Georgia
It only goes down. You have to piece the parts together but let me see if I can find a post that has some pictures and info. Unfortunately I didn't take any. Should have and done a write up on it.
I originally had it set up with a PAC TR7 universal trigger module so I could use a keyfob to drop it (3 press's of the door unlock would open the tailgate) However, because the newer truck's use a PWM 12v signal it was not consistent in interpreting the clicks and didn't work all the time or would drop it after 1 press so had to disconnect it. That was really neat when it worked.
This is the actuator I used. Basically you attach this to the rods that come off the tailgate handle on the inside. Wire it to a relay and switch, when you press the button the actuator pushes the rod and opens the tail gate. Also have a Dezee? hydraulic tailgate assist so it doesn't slam down.
https://www.amazon.com/gp/product/B0009SWLE6/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Trailmaker
Locked and Loaded
Conroe Texas
2021 PW
with a 2019 or 20 key fob you can control it? maybe? I don't use mine every day but when I do, it is a nice feature to have.
mtnrider
Georgia
I was using my 2016 keyfob and a PAC TR7 trigger. But like I said it didn't work consistently because the new trucks use a PWM 12v signal to unlock the doors (what I was triggering off) instead of a steady state 12v so the TR7 had a hard time interpreting the pulses.
This setup would work on older trucks, probably 2013 and older I would guess? Not sure when they went to PWM control voltage though?
I don't think a 19-20 key would work for me since the RF hub is different and it would not read the extra button function?
Trailmaker
Locked and Loaded
Conroe Texas
2021 PW
oh yeah, you are right. the new key fob could not be used. but a viper one could. it will do a steady state 12v
