A_mod_too_far
Curious on what you think the "tick" is, if it isn't lifter tick,and don't say manifolds as that's the only other obvious tick. So if it's not lifters or manifolds what do you think is causing the "tick" that the dealers are missing.
I'm on the train with the people that say the tick is from the rocker arm and pushrod. I dont think its physically possible for a lifter that has just ceased and barely even had a chance to score the cam lobe to tick in anyway being under constant pressure from the valve spring. What's ticking? It has to be a tiny tolerance at the push rod and rocker arm, no one has ever explained it any other way that could make sense to me. What would tick as a lifter slides along a cam lobe? Even ceased
I've seen youtube videos of people pull out freshly ceased lifters with the cam still in tact where the engine was making a very audible tick.
