Buckeye2019
Guys when I switch out the head unit what do I do about the camera. The monitor is in my rear view mirror how does this work
Can you help me out a little... I click on that link and have the option to go to 8.4 or lighting... neither of which I want.The harness connection has a harnes to move the 3 camera wires to the radios C-1 connector that is plug & play . I think it's pretty cheep $$! Like 30 bucks .
The Harness Connection Home
Hope this helps !
Hit the Brows all productsCan you help me out a little... I click on that link and have the option to go to 8.4 or lighting... neither of which I want.
I am replacing my stock RA1 radio with a Pioneer. The Pioneer has a backup cam option. I know I can tap the wires and install my own RCA, but I'm curious about a harness connection that would make a cleaner install...
Great , glad to hear !I received the harness from HC and installed today. everything is working perfectly. Even installed the footwell lights with the harness from HC
Hope the back up cam shows up in your radio , I only have the RA2 5.0 OEM radio and I can back up to my boat perfectly the first time everytime .You are correct RLK. I guess I'll find out! I'll still have the display in my mirror with the grid lines if I NEED it. I just find the OEM camera display lacking when backing up to trailers. My Tundra had a much better camera display in the mirror, so I could perfectly back up to a trailer. I find the Ram mirror display is awful dark, to the point its hard to see exactly where the ball and coupler are when they are close.
