Back window leaking
Regent
Midland
I have a problem with the back power window . Water is leaking in. I had the window changed , once because it broke and once because I thought it was improperly installed but that wasn’t the problem.
Where can the water be coming from . The roof ,the back light ??
Any suggestions ?
TXCOMT
It's not unheard of for our trucks to leak through the CHMSL (center high-mounted stop light)...dig around here in the threads and you'll see a couple of ways to remedy the issue. Some double up on the paper-thin factory gaskets and others have reported dealership techs using RTV sealant! It's a problem we should all be aware of (kind of like the dreaded Hemi tick) but, thankfully, there are some cheap fixes.
TXCOMT
VB712
Maxi_built
Va Beach
More than likely it’s your 3rd brake light.
grizzstang
Calgary, Alberta Canada
I fixed my third brake light with this.
full
full
ctrevino8
The Woodlands, Texas
2018 Hydro Blue Sport
I've had the 3rd brake light leak on 2 of my previous rams. I thought it was the sunroof or the rear glass, but both turned out to be the brake light. Like TXCOMT said, do a search on here, there are a couple of cheap ways to fix them!
Kinetic
To avoid this should I just go ahead and try to put that tape stuff on there ?
rotwiler
Washington
2013 QC Outdoorsman
Even if is not the 3rd brake light, eventually it will leak, so needs done by everyone. I went with a blacked out led one instead, but the gasket on the stock light is super thin and wears out and hardens over time.
Kinetic
Even though mine is 2 weeks old I'm going to get a gasket kit and do it now, just in case.
rotwiler
Washington
2013 QC Outdoorsman
Great! Much better to do now then you won't have to worry about headliner stains in a couple years.
