Ball joint replacement
btyson131
4.7 magnum
Just got a quote of $981 for upper and lower ball joint replacement on both sides of 04 1500 4x4. Does this seem fair? Any response epil be appreciated
RonJon '06
Southern Minnesota
I was just quoted $1,000 from a local shop last month, the allignment was extra. Dealership wanted $1,300 with the alignment.
B
btyson131
4.7 magnum
Yeah. That price included alignment. Thanks for the reply. Just going to have to do it. It has 165k and mech said they wet factory so it was a good run anyway. Thx
xb1230
Hobby Mechanic
South Shore of Montreal, QC, Canada
From a good mechanic shop, that seems very reasonnable. I did both upper and lower on my '02 for 200$. Did it myself. Plus 100$ for the alignment.
Ask the mechanic to have a good look at the lower arm bushings. Mine ended up being bad as well so instead of buying lower ball joints, I would have been better off replacing the whole LCA as I have done with the UCA... Now I have 2 nnew lower Ball joints, and I have to buy LCA's anyhow.
My 2 cents.
Sent from my TouchPad using Tapatalk
Gale Hawkins
Murray KY
5.9L Magnum
We just did the shocks with KYB MonoMax and front stabilizer bar bushings and end links on the 2002 with 111K miles we just bought. It does need all ball joints, 8 bushings and tie rod ends before it is aligned. They are still safe but have a lot of wear. I think the worn shocks may have caused more wear since they offer no resistance to compress them after they were removed. The ride is great now but I want new tires before winter.
