Ballast location?
Rzrman328
The treeline
Where are you guys installing the ballast for the low's ?
I had plenty of cable just not lots of room around headlight.
Galion
Edmonton, AB
Mine's attached to the frame just behind the headlights with double sided 3m. They fit perfectly there for me.
Rzrman328
Rzrman328
The treeline
That's where I ended up putting mine. It doesn't look like there was a whole lot of options.
posttal
Cleveland , Ohio
2011 and 2013 Laramie
Heres mine...My ballast are bolted on since they're a little heavier and the canbus relay being lighter is zip tied to the side of the fuse box...basically the same on the other side...remember they should have air flow because they do get hot
