If you want real gains swap those shorties for long tubes. Get rid of the 90mm throttle body to get some money back, install a 6.4 intake manifold and a ported throttle body. The 90mm is not actually gaining you any power. The 6.4/392 making 485hp uses the same throttle body as the 5.7. A ported throttle will help in the top end a bit. Long tubes will open your whole power band up better plus getting rid of the factory y pipe is a huge plus. Also depending on the cam you will need to look into a higher stall torque converter. Also if you are not currently tuned none of your mods made a difference so tuning will be a pretty good gain anyways before adding in a cam
I did consider long tubes. Trust me I really wanted a pair. However, a few factors made me go w shorties. I wont go catless. Failed a emission test once because of that. So after that I keep it legal. Yes I had to consider the cost of a new cat system and compared to a cat back dual exhaust from single, I had to go with that. Expendable funds. Yea, I'd like to get rid of that Y. Need to find a cheap muffler shop and have a plan. Lol
I also did consider goin with the 6.4 intake, something i know i can do myself.
However, I had already made up my mind and got the Vararam AirGrabber. Very cool old school look, makes me smile every time i open the hood. Small as they my be, definitely some gains.
Anyways, where the throttle body mounts on the 6.4, it doesn't match the Vararam set up. Sadly.
I was a bit aggressive w the 90mm but the response is quite noticeable, still might keep it on for now.
I was goin to wait on getting a torque converter as again funds were a factor, but i noticed that updating my tune wld be additional cost after a torque converter install.
I waiting on a 3600 stall from Moe's.
Damn, the wait feels like forever, lol.
So that was why i scrabbled around to find a Dyno that wld take my truck. Many places said they couldn't fit me.
I wanted to see what gains I wld make w the cam and tune.
My mods are minimal so I'm pretty much stock.
I thought I'd show my progress as my build goes.
