Batter Saver on some systems may have reduced power message
Xman
Idaho
Battery Saver mode on some devices may have reduced power message. I get this periodically after starting with auto start. Then media is unavailable on screen. When I restart truck it goes away .
markabby
Monticello, Kentucky
2020 Limited
copied this....
"In a nutshell, your ride's battery-saver active system maximizes the remaining current on your battery in situations when the battery and alternator do not provide enough current flow. It works similar to the “battery saver” mode you have on your smartphone.Oct 23, 2023"
but, my question is what or why is using more power than what the battery and alternator can supply?
ir, does it mean the battery is weak or old?
X
Xman
Idaho
I wounder the same thing why. It doesn't store a code so dealer is clueless. It's random also. Can go weeks to months never doing it
turkeybird56
Central Texas
It's been a issue for 1+yrs
When is the last time U put a toaster tester on the battery and load tested it? My thoughts are: Battery weak and/or Alternator not functioning correctly. SO I would load test that battery 1st and work from there. You have original battery???
X
Xman
Idaho
Yes original battery
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
either your battery has reached its life span
or
your Alternator's internal regulator is not allowing the alternator to produce more juice.
Mopars internal regulator is set to something like 80% charge rate, at Factory setting
